2wd front lift kit - Page 2 - Ford Truck Enthusiasts Forums
2wd front lift kit
Old 08-18-2013, 02:43 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Quote:
Originally Posted by b-uno View Post
my buddie had a 82 f250 with a 460 and man he would jump that thing, it had the TTB 4x4 front end, couldnt break it!
If there is anything the TTB front end does well at, (besides wearing tires unevenly) it's taking abuse from jumping.
Old 08-18-2013, 09:41 AM
Jarryd's Avatar
Jarryd Jarryd is offline
Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.
Quote:
Too bad my mustang didn't handle jumps well. Barely got her off the ground,bottomed out and cracked the oil pump gears which in turn caused it to develop a knock and bent the rear axle. Now I know how to build a big engine though so hopefully at some point in the next year I'll geta chance to do that for the truck.
Old 08-20-2013, 06:17 AM
Slowroll90 Slowroll90 is offline
Slowroll90 is starting off with a positive reputation.
I've thought about getting the 2 inch lift springs bronco graveyard shows for my 2wd f150, that "kit" also claims to come with the camber bushings.
Maxx Lift Leveling Kit finguru 1968-2013 Full Size Vans 17 03-30-2016 03:19 AM
2003 F350 Alignment powersmoke~ 1999 to 2016 Super Duty 2 01-10-2016 09:41 AM
Need Help!!... Fexx22 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-30-2015 06:20 PM
1 inch coil spacer question 89 ranger Dutter 2 Ranger & B-Series 0 05-26-2014 12:19 PM
Camber Adjustment after Lift SoCal949 2009 - 2014 F150 1 05-04-2014 09:24 PM
Tags
leveling, leveling kit, lift, lift kit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
