Tiffin RV 35QBA - Unusual High Pitch Noise from Engine Compartment/Dash - Ford Truck Enthusiasts Forums
Old 08-17-2013, 01:04 PM
rvjoe rvjoe is offline
rvjoe is starting off with a positive reputation.
This is a copy of a post I placed on tiffinrvnetwork.com. The chassis for the 35QBA is a 24,000LB F550. Posting here to see if any Ford enthusiasts can help identify the noise we are experiencing.
We bought a 2013 35QBA in January of this year. During the first three months of owning the rig we noticed a high pitched noise coming from the engine compartment/dashboard area. This only seemed to happen when we had the 16' utility trailer with our dirt toys in tow. We took it to our local Ford dealer, told them about the noise, and left it for a week with them. They reported back that they were unable to reproduce the noise and let them know if it happens again.
Since then we have had that same noise towing up hill......going down hill when the transmission down shifts, and sometimes just while driving mostly flat roads with some rolling hills (think Oklahoma and Texas flat). It also appears to happen more frequently when it is warmer outside ( above 88-90 or so). We have been on our summer vacation in the RV for the past 7 weeks and have been dealing with the noise the entire trip. We took it to a Ford dealer in Branson MO because we had a time share to stay at for that week. We took the tech for a ride with the trailer attached and he was able to hear the noise....unfortunately he was not able to find the issue nor reproduce when the trailer was not attached.
Since we have tried twice at Ford I thought I would post this question along with a link to a YouTube video of the noise as it happens. The noise in this video is the high end of the spectrum...there is a quieter version of the noise that also occurs on a regular basis but is very hard to hear over the engine noise. To see / hear the video click below.
During this video you can see that the RPMS are around 4K and we are doing ~70. This same noise can happen at 2.5K RPMS and 50 MPH....extremely variable and frustrating.
We have weighed and the trailer with toys comes in around 3500-3700 pounds depending on the combination of toys on the trailer and the real axle runs right at maximum load. Typically we usually carry about 1/3 tank fresh with us at all times.
Any insights would be appreciated as this is becoming very annoying to deal with on a daily basis while we are on the road.
Thanks,
Joe
Old 08-19-2013, 11:11 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Wow, that's a new one...
First, I'd go back to the (or any) dealer with that video and let them know exactly what it sounds like.
Could be intake noise, could be just about anything. It's more of a whistle than a squeal, yes?
Old 08-30-2014, 12:43 AM
griffin1808 griffin1808 is offline
griffin1808 is starting off with a positive reputation.
I have the same problem
Thank you for posting this, we have the same problem our RV is in for repair and they have not heard of the problem. We're you able to figure out what the problem is, and did they fix it? Your reply will be greatly appreciated
Old 02-09-2015, 01:43 PM
turbodan1 turbodan1 is offline
turbodan1 is starting off with a positive reputation.
I also have a 2013 tiffin motorhome and its at the dealer for the same problem. They have no idea what it is. I will post if they can find anything.
Old 02-18-2015, 02:38 PM
KellyfromVA's Avatar
KellyfromVA KellyfromVA is offline
KellyfromVA is gaining momentum as a positive member of FTE.
My guess is a vacuum leak, either from the intake manifold or a hose. That being said, vacuum would be less under heavy acceleration, so not sure why that would pop up then. What about spark-arching to ground from a bad coil pack(s)?
Old 07-16-2016, 09:35 PM
Jillaginn Jillaginn is offline
Jillaginn is starting off with a positive reputation.
Same noise - 2015 Tiffin Open Road
Did you ever figure out what this noise was? We have the same problem now. Thanks!
Thanks,
Joe[/QUOTE]
Old 07-17-2016, 11:25 AM
Krewat's Avatar
Wow, that's weird. Have you tried turning off the AC/Climate-control stuff when it does this?
It almost sounds like a vacuum actuator leaking. Do you have climate-control?
Old 07-19-2016, 09:51 AM
super 6.8 super 6.8 is offline
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
Is that a bearing squeal in the accessory drive?
Old 07-19-2016, 11:13 AM
Krewat's Avatar
Quote:
Hmm... could be... AC compressor clutch bearing? Which brings me back to the climate control. Does turning on and off the AC change the squeel?
Old 07-19-2016, 12:39 PM
On the road again again today
I'm on the road again today and am going to try to replicate the noise with the A/C off.
Turbo Noise in Tow/Haul while decending RobFlag 6.7L Power Stroke Diesel 8 09-26-2016 06:29 PM
Intermintent High Pitched Squeel daveplot 1997-2006 Expedition & Navigator 1 09-05-2016 12:10 PM
210 Ford F250 High Pitche Ringing...Also dash knocking noise moreammo 6.4L Power Stroke Diesel 6 04-27-2015 09:33 AM
VCT? Cam? Timing? (w/ video) Laura.311 2004 - 2008 F150 2 03-28-2015 11:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
