4.2 L Tune Up - Ford Truck Enthusiasts Forums
4.2 L Tune Up
Old 08-17-2013, 09:12 AM
winklershop winklershop is offline
winklershop is starting off with a positive reputation.
4.2 L Tune Up
I have a 2006 Ford F150 with the 4.2 L and i am looking to do a 150,000 mile tune up.
What do you guys normally do for tune up?
I was thinking spark plugs for sure, has this engine been known for breaking spark plugs? or is that only on the 5.4 L?
Serp Belt
all oils and filters change out
what else is good to do?
Thanks for all the help!!!
-winklershop-
Old 08-17-2013, 12:49 PM
Ducky F150 Ducky F150 is offline
Ducky F150 is starting off with a positive reputation.
The breakin plugs is on the 5.4 if its cop check the boots too everything else you listed is standard items to be done
Old 08-22-2013, 04:42 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
You might consider injector,fuel log/throttle body cleaning service. Along with the spark plugs, I don't know of any other service. I use a fuel additive all the time because we only have E10 here.
7.5 L 460 nightmare winklershop 1987 - 1996 F150 & Larger F-Series Trucks 8 07-12-2016 05:40 PM
high pressure oil rail end caps winklershop 6.0L Power Stroke Diesel 28 04-10-2015 10:20 PM
CRACKED HEADS 6.0 winklershop 6.0L Power Stroke Diesel 12 12-10-2014 05:04 PM
6.4 L thermostat seals sucked into engine! winklershop 6.4L Power Stroke Diesel 21 02-12-2014 12:38 PM
STEALTH DELETE AND TUNE winklershop 6.0L Power Stroke Diesel 7 01-15-2014 12:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
