1997 F350 front fuel tank inoperative - Ford Truck Enthusiasts Forums
Old 08-17-2013, 01:39 AM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
This is the newest automobile I own, so I'm not knowledgeable in this area.
Recently the front fuel tank will not supply the engine with fuel. The rear tank is operational. However, I prefer to use the front tank because it's safer than the rear. The fuel gauge while on front registers fuel. Just to make sure, I put in five gallons of fuel in the front tank. It still will not supply fuel.
How can I diagnose this problem, whether it's mechanical or electrical? The only thing I can think that is, are the fuel tanks fitted with an individual pump inside both tanks, or something else as one works, the other doesn't.
Old 08-17-2013, 07:20 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Is the truck a gas or diesel engine model?
Old 08-17-2013, 01:25 PM
Island'r's Avatar
Island'r Island'r is offline
Island'r is gaining momentum as a positive member of FTE.
Can you hear the front pump when you turn the key to ON without starting the truck?
Old 08-20-2013, 03:07 AM
Quote:
It is a gasoline truck. It has the 5.8L.
Quote:
Would it be loud enough? I'm nearly deaf, so that may be not possible to just hear it. I'd have to confirm with a multimeter.
Old 08-20-2013, 07:40 AM
rla2005's Avatar
Each tank has it's own high pressure fuel pump inside. There is a common power path from the fuse, fuel pump relay, through the inertia switch then onto the fuel tank selector switch on the dash.
For reference (very similar to your truck):
courtesy of oldfuelinjection.com
91 150 fuel dual fuel tanks nann69 1987 - 1996 F150 & Larger F-Series Trucks 1 11-21-2015 03:39 PM
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 09:14 PM
bypassing tank selector valve cdat81986 1987 - 1996 F150 & Larger F-Series Trucks 7 10-02-2011 04:31 PM
89 F150 4x4 Dual Fuel Tank Switch predaina 1987 - 1996 F150 & Larger F-Series Trucks 29 03-29-2011 07:07 PM
Bypass front tank rjaywhit 1987 - 1996 F150 & Larger F-Series Trucks 7 10-07-2009 09:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
