Best source for front axle gears
Hello,
I have a 1964 Mercury M-250 4x4, with a low pinion Dana 44HD. I have swapped out the rear axle for a later model with 3.73 gears. I can now drive my truck at a pretty comfortable speed. Looking to locate the best place to source a new carrier and a 3.73 gear set for my front axle. Most place only offer these parts for a high pinion axle. Does anybody have any suggestions?
Thanks,
John
Thanks,
John
Ford F-250 3/4 Ton Front Differentials Dana 44, 19 Spline Ring & Pinion Sets
You will also need a different carrier for 3.73 and down (numerically) gear ratio,
Ford F-250 3/4 Ton Front Differentials Dana 44, 19 Spline Carrier Cases
Originally Posted by 3360stepp
I understand it has 19 splines, based on some assumptions.
Look at the two pics for 4851 .. the companion flange that the splines of the 4WD's front driving axle pinion gear fit into.
1959/72 F250: It's C1TT-4851-F .. 10 splines.
scottek
11-14-2005 05:17 PM
acbaldwi
07-20-2003 09:50 PM
