2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
08 Expedition transmission "jump"
Old 08-22-2013, 04:04 AM
Nickybear's Avatar
Nickybear
Nickybear is offline
I have an 08 Expedition Limited 4wd. Anytime I accelerate from a stop the tranny jumps into first and bounces forward. And the opposite as I'm approaching a stop, right before I reach a complete stop it jumps forward a little bit. I say a little bit to stress that its not pulling the truck forward as to be unsafe, but its a very hard bump. Other than that it runs and shifts fine. It seems to be getting worse.
I just had the dealerships $650 "tune up" done, not sure what all that entailed but it ran much better after having that service done. It did this transmission jump thing very slightly before I had the tune up. It's bad enough now that passengers notice and ask what it is.
I'm supposed to leave from Dallas TX driving to Northern Nevada for burning man. About a 30 hour drive each way. And much of it is hundreds of miles of desert with nothing around for a few hundred miles really don't wanna break down out there.
Also my gas mileage sucks. I get no better than 9 ever, used to get 12-13 hwy.
Any thoughts? There are no codes or warning lights up.
-Nick
Old 08-24-2013, 11:49 AM
sandrat's Avatar
sandrat
sandrat is offline
Can't remember for sure, but I think there is a reprogram available for the PCM to cure this problem.
Old 08-24-2013, 05:18 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
If I am not mistaken 08, maybe it was 07, had a TSB for removal of the trans and installation of a clutch pack to help prevent the rough shifting.
Old 08-24-2013, 05:56 PM
Nickybear's Avatar
Nickybear
Hmm
I've read a few other posts. It only happens after 15-20 minutes of driving. Which kinda leads me to think its not a programming issue. Guess ill just have to take it in :-/
Old 08-24-2013, 07:22 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Montecarlo31,
The clutch pack one was for the downshift "sqauwk" noise. TSB 09-6-1
Nickybear,
The one for the "bump stop" is TSB 08-22-7 this is a simple reflash of the TCM. Dealership will probably charge you whatever the 1 hr rate is.
Matt
clj828
16
02-28-2020 09:04 PM
Nickybear
1997-2006 Expedition & Navigator
08-21-2013 02:19 PM
devildogmech
17
01-07-2008 01:10 AM
builtfordtough13
01-02-2008 11:00 AM
davisenvy
11-16-2005 09:15 AM
Quick Reply: 08 Expedition transmission "jump"
