Engine Advice
Engine Advice
I am looking to replace the tired 1974 351W in my 54 with a non-roller 351W out of a 1996 van. I currently have C-6 tranny. I have couple of questions. First is there an easy (i.e. cheap) ay keep the fuel injection. Second, if I go carburated can I use my intake, distributer, fuel pump and timing gear cover off of my 74 351W. If anyone has any experience with the above options I would appreciate your input.
I know the older 351W had a different deck height or something that requires different heads or intakes not sure what year that ended. You should post your question over here also and you may get more responses.
Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums
I am looking to replace the tired 1974 351W in my 54 with a non-roller 351W out of a 1996 van... if I go carburated can I use my intake, distributer, fuel pump and timing gear cover off of my 74 351W. If anyone has any experience with the above options I would appreciate your input.
medino03
05-14-2012 10:24 AM
75highboy
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
05-14-2003 02:47 PM
