Belt tensioner wobble. Also burning coolant...
Actually just changed plugs a few weeks ago and the old ones came out looking whitish (running hot and lean?) Plug #3 keeps wanting to wobble loose even though I used a torque wrench to correct specs. When it is in there good and tight the truck never misfires.
Is your belt tensioner original? If so, replace it. They wear out over time and don't hold proper tension. Get a good one from Gates or from Ford. I put on a Dayco and it was crooked out of the box. You mentioned that one spark plug keeps backing out- are the threads in the head damaged at all? How are you bleeding the cooling system? You may have some trapped air pockets, so the coolant is low each time you check it. Coolant in the exhaust is typically an intake gasket or head gasket (as previously mentioned).
That's odd that the socket is getting stuck. You're using a 16mm spark plug socket, correct? Is there an excessive amount of rust build up on the head around the plug hole?
IMO if your cooling system is that full of junk, I would drain it completely and replace the hoses. By repeatedly trying to flush it you run the risk of clogging the radiator, heater core, or both. Also replace the thermostat since it could be getting clogged with crud. The best tool I've used for burping the system is called a Spill-Free Funnel. The kit runs $20-$30 and includes the funnel, plug, and adapters to cover 90% of what you'll encounter.
FWIW, if somebody dumped head gasket fix or stop-leak in the system it will cause you some grief. If everything is packed full of muck you may have to replace the radiator and heater core as well. Rent a pressure tester from the local parts store and pressure test the system and the cap. That will help you find the leak.
I just replaced the thermostat when I did the flush. I will need to do another flush soon to try and clear all that rust and when I do I will get some new hoses.
The stuff clogging it up looks like that Barr's Stop-Leak junk. Like a fine brown sediment. The petcock had a leak in it and I think the previous owner couldn't figure that out so they filled it with that junk. New petcock cost me $3 and now leak free!
bakerbuilttracks
28
11-21-2012 01:59 PM
Mark53207
06-01-2004 04:48 AM
