codes P1151 and P0133 - Ford Truck Enthusiasts Forums
Old 08-16-2013, 12:03 AM
oldford65 oldford65 is offline
oldford65 is starting off with a positive reputation.
HI yall, I have a 1999 explorer with a 4.0 ohv auto with about 174,000 miles on it. the PO changed the coil pack,wires,plugs,MAF and cat on it trying to get rid of codes. I know the from searching that they are both precat 02 codes. So im planning on looking for vacumn leaks with propane around intake and egr and checking on the fuel pressure and wiring and connections. Is there any thing else I should check out? for both sensors to throw this code? The truck runs ok just has a shutter when going up hills and stuff.
Old 08-16-2013, 07:39 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Per the factory service manual, the following are possible causes of the P0133:
  • Contaminated HO2S sensor.
  • Exhaust leaks.
  • Shorted /open wiring.
  • Improper fueling.
  • MAF sensor.
  • Deteriorating HO2S sensor.
  • Inlet air leaks.
For the P1151, the manual references P1130:
  • Electrical:
    • Short to VPWR in harness or HO2S
    • Water in harness connector
    • Open/Shorted HO2S circuit
    • Corrosion or poor mating terminals and wiring
    • Damaged HO2S
    • Damaged PCM
  • Fuel System:
    • Excessive fuel pressure
    • Leaking/contaminated fuel injectors
    • Leaking fuel pressure regulator
    • Low fuel pressure or running out of fuel
    • Vapor recovery system
  • Induction System:
    • Air leaks after the MAF
    • Vacuum Leaks
    • PCV system
    • Improperly seated engine oil dipstick
  • EGR System:
    • Leaking gasket
    • Stuck EGR valve
    • Leaking diaphragm or EVR
  • Base Engine:
    • Oil overfill
    • Cam timing
    • Cylinder compression
    • Exhaust leaks before or near the HO2S(s)
The descriptions for the P0133 relates to frequency and amplitude, for P1151 it seems to be more focused on amplitude, and specifically a rich condition. In the list above for P1130 you can probably ignore situations that would cause a lean condition, at least for now. If it were me, I'd start by checking fuel pressure along with how quickly the rail pressure drops when the key is turned off.
What's a bit confusing about the P1151 is if you only look at the code name versus the code description it could send you down the wrong path. The code name states:
"P1151 - Lack of HO2S-21 Switch, Sensor Indicates Lean"
While the code description is listed as:
"A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when fuel control system no longer detects switching for a calibrated amount of time."
-Rod
Old 08-16-2013, 07:47 AM
Thank you for the info and your advice! I will start with the fuel pressure. To my understanding it should be around 60-65. I will check it later today and report back.
Old 08-16-2013, 03:13 PM
Well my harber freight fuel pressure gauge gave me different readings. I hook it up and started the car reading 30 tapped the gauge and it went to 65. Cut the car off and pressure dropped. Retested pressure 60 cut the car off and pressure stayed. So have to get a better tester. Could find no leaks with the propane.
Old 08-16-2013, 03:21 PM
It does have NGK plugs in it TR55 3951 could they cause any of it?
Returning P0276 code... davidlea 1999 - 2003 7.3L Power Stroke Diesel 12 12-30-2011 06:24 AM
P1335 Code i eat hybrids 6.0L Power Stroke Diesel 13 12-17-2010 12:24 AM
codes p0316,p0300,p0302,p0303 soto8704 2004 - 2008 F150 5 09-28-2010 11:21 PM
Code P 215A grider 1999 to 2016 Super Duty 5 04-15-2009 11:58 AM
2000 ranger 4.0 code p1451 paulmdahle Ranger & B-Series 3 01-23-2009 03:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
