99 f150 trouble codes 171,174, and 455
Old 08-15-2013, 10:07 PM
69ford99's Avatar
69ford99
69ford99 is offline
Truck runs fine and a while back I had just code 171 and replaced the whole PVC assembly and the code went away but now I have codes 171,174, and 455. Im guessing they are all related. Can someone point me in the right direction.
Old 08-16-2013, 12:18 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Well tell ya what!
You didn't fix the first 171 code because it's back with it's partner 174.
These codes are related due to the same cause, an intake air leak affecting both banks.
The 455 is the fuel tank system diagnostics----- a gross leak detected.
The cap , fill pipe, stuck open solenoid or some hole, and not normally related to 171/174.
Good luck.
keninwa
2009 - 2014 F150
06-30-2016 12:32 PM
dsnyderdsnyder
1997 - 2003 F150
09-27-2013 10:34 AM
n5926g
1997 - 2003 F150
10-25-2008 10:12 PM
Terrafermi_1
Modular V8 (4.6L, 5.4L)
03-07-2004 12:41 AM
drighten
Garage & Workshop
04-04-2003 07:14 PM
Quick Reply: 99 f150 trouble codes 171,174, and 455
