1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
the DREADED "Check Electronic Throttle Control" Need HELP
Old 08-15-2013, 07:36 PM
Iron782's Avatar
Iron782
Iron782 is offline
Unhappy the DREADED "Check Electronic Throttle Control" Need HELP
Ok the back story, truck ran good. Lights got left on and battery went dead. Jumped it the next morning and the message came on. Tried disconnecting battery for code reset. No luck. Replaced TPS with Borg Warner, no luck. replaced throttle motor with new Dorman, no luck. Cleaned throttle body, no luck. Inspected pedal sensor, all clean. Bought Bluetooth code reader and downloaded TORQUE app. here are the codes. P2104 TACS forced idle, P2111 TACS stuck open, P1000 Powertrain Monitor Incomplete, U2023 Network, B1318 Body, U2013 Network, U1900 Network. The truck has had Catalytic issues for awhile after a stuck fuel injector that was replaced, ran fine just crappy MPGs. Im at a dead end here. ANY help or suggestions???
Old 08-15-2013, 10:32 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Sorry can't help ya, but I would try staying in the original thread you started. I just erased what I wrote thinking this was a new member with a similar problem as your own.
gstanfield
6.2L V8
58
03-02-2024 09:57 PM
mirae1
2009 - 2014 F150
09-10-2018 12:51 PM
RickBraden
05-03-2015 09:07 AM
LilToe
12-04-2012 11:53 AM
magnet1
2004 - 2008 F150
12-17-2010 02:29 AM
Quick Reply: the DREADED "Check Electronic Throttle Control" Need HELP
