Do you burn premium when towing? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 08-15-2013, 07:40 AM
22rimfire 22rimfire is offline
22rimfire is gaining momentum as a positive member of FTE.22rimfire is gaining momentum as a positive member of FTE.
This has probably been discussed before, but there might be some new owners that could chime in. I'll be towing the travel trailer for the first time this weekend (approx 7K lbs), and was wondering if the stock PCM recognizes and makes any adjustments for higher octane? Or is it just a waste of money? I'll expect to go through two tanks on this trip, and was thinking of burning reg on the first, and prem on the way home just to see if I noticed a diferance. No big hills on this trip, and we're heading to the coast so will be at or near sea level. Only 900 miles on truck so it's not even broke in yet. Anyway, your thoughts? Thanks, and I'll post up a trip report when I get back.
Old 08-15-2013, 07:47 AM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
Running a gas with higher octane rating than what the engine is designed for does nothing. Higher octane rating only means the fuel is more resistant to compression-detonation.
Now, if the "premium" fuel also has no ethanol in it, that is a different story. Some stations in some states still sell gas without ethanol as a selection at the pump, but it is getting harder to find.
Old 08-15-2013, 07:57 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
This is incorrect.
Running premium in the 6.2 will yield you more hp. This was confirmed by the 6.2 engineer back when he was around answering questions here on FTE.
Old 08-15-2013, 08:26 AM
thomabb's Avatar
Running higher octane rated fuel than what the engine is designed for alone can not improve HP - it defies physics.
Now, if the "knock sensor" is sensing pre-ignition and retards the ignition timing to protect the engine, HP is reduced. I did not see the q&a with the 6.2 engineer, but maybe that was what he was referring to?
What is the minimum octane rating required for your truck? Does the manual specify different fuels for different conditions?
Old 08-15-2013, 08:48 AM
thomabb's Avatar
"Octane is defined as a fuel's resistance to knocking. There is no benefit if the octane is higher than what the engine needs. Engine knock occurs when fuel in a combustion chamber ignites before it should. This disrupts the engine's operation. But electronic knock sensors are now common and have nearly eliminated engine disruption." - California Energy Commission Consumer Energy Center
All the research I read over the years on this subject reads almost exactly as this quote summarizes.
I will also throw out there that there is no tangible detriment to running higher octane fuel, other than to your wallet. So I can see why people choose to pay a little extra for the peace of mind.
Old 08-15-2013, 09:01 AM
thomabb's Avatar
Old 08-15-2013, 09:10 AM
Old 08-15-2013, 10:03 AM
thomabb's Avatar
Thanks for that link. So the octane rating recommendation for these motors is purposely understated so the knock sensor controls engine timing more frequently? I did not know manufacturers were doing this.
So does your manual suggest different fuels for different conditions? My newest gas motor is a '08, just curious.
Old 08-15-2013, 11:01 AM
Thanks for the replies guys. So the Ford engineer says 10 HP gain. While that's nice, I'm not sure it's worth the extra .30 cents a gallon I have to pay around here for 91. I think I'll stick to the reg this weekend and see how it goes. When I tow in the mountains it might be worth trying though.
Old 08-15-2013, 11:04 AM
Quote:
I Don't remember seeing anything in mine (coulda missed it I'll check when I get home). I know the EcoBoost does.
Old 08-15-2013, 12:55 PM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
I run E10 87 or 89, in some of the midwest states E10 is reg 87 with 10% ethanol added to makes it 89. Runs just fine on the lower octane is was designed, I see no need to run the higher priced octane gas.
Denny
Old 08-15-2013, 02:22 PM
I don't ever recall seeing anything where they recommended different grades of fuel for different conditions, but if you wanted a little extra hp, the option's there.
I'm running a 93 tune so I get more than a little extra hp. My tires are paying for it, already ready for another set before winter sets in.
Old 08-15-2013, 09:35 PM
BigMix's Avatar
BigMix BigMix is offline
BigMix is starting off with a positive reputation.
Try Premium Fuel without ethonal. I have tried premium but really couldn't see/feel the benefit. Of course I don't have a tune. Still trying to find a good station locally that has the straight stuff.
Old 08-15-2013, 11:59 PM
6.2gasser's Avatar
6.2gasser 6.2gasser is offline
6.2gasser is starting off with a positive reputation.
I notice 1-2 mpg yield difference in the octanes. I put premium in frequently, less trips to the pump.
Old 08-16-2013, 07:55 AM
Went ahead and filled up last night with 87. Pretty much everything around me has "up to 10%" ethanol. It was $102.31 when it clicked off at 3.79 a gallon. I think I was wrong about needing two tanks for our trip. It's only around 95 miles to the state park, so might make it on one tank if we don't run around too much. Leaving in a few hours and I'll be off the grid till Sunday night. Later
Today will be my first fill up... sessland Excursion - King of SUVs 15 07-29-2014 04:56 PM
Please Help: Horrible Burning Smell While Driving BuckHammer 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-15-2012 12:42 AM
First Tow with 6.2 kmonty2 6.2L V8 35 07-25-2011 10:27 PM
First Towing Trip and Good Report!!! jim48 6.7L Power Stroke Diesel 10 06-03-2011 09:30 PM
Overdrive OFF light flashing question bc2sv 1999 - 2003 7.3L Power Stroke Diesel 21 03-05-2010 04:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
