"lowered" the front end - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 08-15-2013, 08:08 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
When I got my F250 the front leaves were sagged - very common with the usual & obvious signs - front springs bending upward in the middle and front sway bar ends poking down.
I rectified this by importing a Tuff Country Levelling Kit. Leaf packs of 5 leaves each are added under the stock springs and bolted together with the supplied longer U-bolts.
The results was a "4 lift over the sagged height & and increase from 50mm or front suspension travel to 100mm of suspension travel. To equalize I swapped out the standard rear blocks and put in 3" blocks, and in order to soften the ride I also took out the short fat bottom leaf from each side at the back.
After all this the truck never looked quite right because the front looked more lifted than the rear.
So I'm swinging spanners last night getting warmed up, and figure it is time to 'adjust' the front suspension down a bit. 4 hours later the truck is back together after taking the smallest 2 leaves out of each of the front spring-packs - still leaving 5 leaves each side, & still having 100mm of front suspension travel.
All round the truck now the gap between the top of the tyre and the top of the wheel arch 26cms.
Finally, truck LEVELLED for the first time.
While I'm keen I'm planning to do the G2WW change over this w/e.
Old 08-15-2013, 10:03 AM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 has a good reputation on FTE.aussie_f350 has a good reputation on FTE.
Can't wait to hear about the ww!
Old 08-18-2013, 02:15 AM
Hauling horse-flesh today.
Front end is more compliant now, even my wife said that she thought it was more comfortable. And the nag (i.e. the horse) wasn't screaming in the back.
Re-torqued the U-bolts when I got home, and pulled the steering rod shorter 1 turn to get the steering wheel straight again.
Good results!
G2 WW is next.
V/Modified B codes, step-by-step robert_l_ross Excursion - King of SUVs 233 04-21-2016 09:16 AM
Comprehensive "Steering Wander" Thread Compilation Stewart_H Excursion - King of SUVs 112 01-28-2014 06:27 PM
2.5" Leveling Kit + V/C code Install = 4.5" lift!!! RMBC Freeride Excursion - King of SUVs 42 11-25-2013 04:11 PM
1989 F350 leveling options? lvin4jc 1987 - 1996 F150 & Larger F-Series Trucks 28 03-03-2012 07:55 AM
Cheap DIY 6" lift for 4X4 Super Duty Under Pressure 1999 to 2016 Super Duty 40 02-27-2010 10:33 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
