2007 Expedition Not starting after a flat tire - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-15-2013, 03:08 AM
Mel Bayoumy Mel Bayoumy is offline
Mel Bayoumy is starting off with a positive reputation.
I tried starting my Expedition and it failed, I got out to check the engine and noticed the car leaning on its right side, the rear right tire was flat, changed the tire and tried to start the truck but with no luck, I was advised to push the reset fuel shut off button, but again with no luck.
If any one has a clue on what might have went wrong, please let me know I would appreciate it very much, thanks
Old 08-15-2013, 05:33 PM
skidog223 skidog223 is offline
skidog223 is starting off with a positive reputation.
how much fuel is in the tank? mine did the same thing few weeks ago with 28 miles left in tank and it started and ran for 10 sec then shut off.. i knew right away what it was .. but i checked everything any ways ..take air box off an while tring to start it spray starting fluid in tb it should fire over .. if it does then change the fuel pump its easy to do i did it in 2 hrs in driveway ..
Old 08-19-2013, 06:27 PM
eveready77's Avatar
eveready77 eveready77 is offline
eveready77 is starting off with a positive reputation.
Oddly enough, my wifes Expedition did about the same thing Saturday. She took it to the tire place who just put tires on it about a month ago because she had a low pressure warning light. the found a nail in it and patched it. When she got home and shut it off it wouldn't start again. engine cranks but wont fire up. I'm not hearing the fuel pump running so about to drop the tank and check it out. At least it happened in the driveway and not out on the road.
Old 08-20-2013, 11:25 PM
eveready77's Avatar
Skidog, any advice on getting the tank out? I consider myself pretty handy with tools and have worked on quite a few older vehicles but this is kicking my butt. The tank is dropped down but seems to be wedged between the rear floor pan and the rear sway bar. The elecrical connecter is also not wanting to come off after removeing the red lock out tab. Is there another "lock tab" holding it on? I'm not far from getting the sawzall out... hahaha
Also the lock ring holding the pump in is a p.i.t.a.!
Old 08-22-2013, 11:23 AM
eveready77's Avatar
Mel bayoumy, have you had any luck with your Expedition? I got the old fuel pump out of ours lastnight and found it burnt up at the electrical connector as others have found too. might be worth checking it out. If your fuel pump fuse and relay are both operational and you still dont have any fuel pressure at the schrader valve on the fuel rail, chances are pretty good your pump is shot. Hope to have the new pump in this evening, weather co-operating, and get ours back on the road.
Old 08-26-2013, 10:28 PM
eveready77's Avatar
Got the Expedition back on the road Thursday night. I bought a fuel pump for a regular Expedition, (readily available vs. the one for the EL) and simply swaped the pump its self as the it is the same from both trucks. The whole assembly is different between the two but you can re-use the stuff from the EL and get back on the road. Maybe this will help some folks who have a high dollar yard ornament waiting on Ford to put out fuel pumps for the L again.
Bad vibrations 2013 f350 (new tires) Softcheeks 1999 to 2016 Super Duty 7 03-14-2016 04:44 PM
2002 Expedition wont crank swintbrian Expedition & Navigator 9 01-19-2016 04:24 PM
Rear Spare Tire Mount greg807 Excursion - King of SUVs 8 03-30-2015 10:26 AM
VSS Wire location on Lincoln Navigator svtman99 Expedition & Navigator 18 02-21-2015 08:13 AM
2010 expedition won't crank Borolf 2007 - 2014 Expedition & Navigator 3 12-23-2014 01:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
