1989 F250 Project
Old 01-25-2015, 07:11 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Damn that sucks.
Might as well add 1992-1996 cabs to your search to open up leads. Regardless of if you want a brick or OBS nose, the cab is the same.
  #212
Old 01-25-2015, 09:34 AM
Vadis's Avatar
Vadis
Vadis is offline
My worry about the 92+ cabs is the plug and firewall issue. The wiring would be an annoyance more then anything.
Although if the right parts truck comes about a newer interior wouldn't be out of the question. Just has to meet some requirements.
  #213
Old 01-25-2015, 12:25 PM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
Keep on the 87-91 cab!! I went with a 92 cab on my 89, and it was a real PITA. Everything looks the same, but most of the important parts are off by just that little bit to make things a real headache. If i ever do it again, i will go with a 87-91 cab for sure. Take a look at this album, the red cab is a 92, the blue one is my stock 89:
89 Rusty Cab Photos by huston123_99 | Photobucket
  #214
Old 01-25-2015, 01:46 PM
Vadis's Avatar
Vadis
Vadis is offline
If It ends up being a 92+ cab I'll try to piece together an OBS interior rather then the bricknose. All because of that fact. I have a 94 super cab parts truck the me and my brother tore apart and found out the steering column, e-brake and few other things were off from the pre-92.
  #215
Old 01-26-2015, 08:22 PM
Vadis's Avatar
Vadis
Vadis is offline
The box I mentioned earlier wasn't as mint as I thought but I was definitely better then what I had. Going to try to go pick it up this weekend. So that takes care of that.
Still hunting for a cab. Got a few leads. My Brother-In-Law's friend has a 94 parts truck he'd sell me for $200 that isn't too bad off from what I can see from pictures. Some rust in the cab corners, door pillar corner and a little but under the doors. Would have to gut the interior to see about the floor.
It needs a complete new interior though.
Another guy down in southern BC might have a 95 cab for me and he's willing to deliver but he's on vacation at the moment so I have to wait a few weeks to get better pictures and more info. That one might be better since it comes from a place with less snow
  #216
Old 01-27-2015, 03:24 PM
NFLD FLARESIDE's Avatar
NFLD FLARESIDE
NFLD FLARESIDE is offline
Good news so far
  #217
Old 01-27-2015, 04:45 PM
emspjay's Avatar
emspjay
emspjay is offline
Wow didn't want to hear that news, that sucks! Glad your digging out and keeping on with your build!
  #218
Old 01-27-2015, 07:38 PM
Vadis's Avatar
Vadis
Vadis is offline
Too far along to give up now!
  #219
Old 01-31-2015, 06:16 PM
Vadis's Avatar
Vadis
Vadis is offline
With cash in hand I went to go pick up that box but found some more rot I had overlooked when I was checking it out before. I walked away with the seller saying he'd let it go for $300 if I changed my mind. Honestly it would've taken another $300 to get it solid. Back to square one again.
Got another lead on another box but this one will have to wait for the snow to be gone.
  #220
Old 02-15-2015, 11:39 PM
Vadis's Avatar
Vadis
Vadis is offline
Well I'm back with some better news.
Last weekend I went and looked at box that looks pretty strong candidate for my build. The truck had a tree fall on and the front panel of the box is pushed down slightly but other then that looks really good. Has a spray in bed liner and a really solid tailgate.
Obviously when conditions are better I'll be able to check the ribs underneath but hopefully it's just a nice below as it is on the outside.
Today I went and looked at a cab. '95 F250. Without ripping out the interior I poked around most of the trouble spots on these cabs and it looks like it's in better shape then my original cab. Checking underneath as best I can and it looks like the floor is solid. The doors are in better shape then the one donor truck's doors I was going to use so that's a bonus.
I'm going to have to track down a power interior in grey and possibly a mid-90's 4.9L truck's wiring harnesses but it looks like I should be back on track assuming nothing major pops up on this stuff.
  #221
Old 02-17-2015, 08:29 PM
MR KROGOTH's Avatar
MR KROGOTH
MR KROGOTH is offline
Any major reason you went to the Super Duty style bed bolts?
Personally would warn against that decision.
  #222
Old 02-17-2015, 11:35 PM
Vadis's Avatar
Vadis
Vadis is offline
I went with the Super Duty bolts to make removable of the bed easier down the road incase a fuel pump goes out or something like that. I've heard the Super Duty bolts can rust up and the top can strip out. In the off chance none of that happens then it's just a Allen wrench and I can remove them without having to weld a nut to the top and getting a 2nd set of hands to help.
  #223
Old 02-18-2015, 12:52 AM
MR KROGOTH's Avatar
MR KROGOTH
Never had a top strip out - but I have broken quite a few impact-rated bits in impact guns over the years, on trucks barely 5-7 years old. Mind you, I'm down in Houston, Texas area and we don't get the salt/rust you guys up north do. Wouldn't want to imagine how bad they get up north. Sometimes even welding a nut to the top doesn't work either - have to grind the top off, get the bed out, then cut the rest of it out.
If you have already spend the money, go for it. I'd recommend coating them in waxoyl/grease if you can. And it never seem to be off chance - I dont think we've ever had a SD come in that we worked on/in/under the bed that didn't have issues getting the bolts out.
  #224
Old 02-18-2015, 11:19 PM
Vadis's Avatar
Vadis
Vadis is offline
I already have them. I had planned to Never Seez, wrap that in Teflon tape and then another coating of Never Seez. Bed bolts do rust up like crazy up here. I've had to do welding nuts to the top, melt them with a torch and grind the tops off methods of removing them. If some of the Super Duty bolts come out then it's a win over normal carriage bolt and if not then I'll just have to do one of the methods I've used before.
  #225
Old 02-18-2015, 11:24 PM
MR KROGOTH's Avatar
MR KROGOTH
In any case, good luck with the build!
Quick Reply: 1989 F250 Project
