E-150 Fuel Tank Modification??? - Ford Truck Enthusiasts Forums
Old 07-07-2002, 10:44 AM
Quality 1 Quality 1 is offline
Quality 1 is starting off with a positive reputation.
I would like to put a larger fuel tank into my 87 E-150. My van only has one tank installed. Is there a larger Ford tank that I can install without a major hassle?
Old 07-08-2002, 11:48 AM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
I see in the J.C. Whitney catalog "Extra-Capacity Replacement Gas Tanks." It shows several for your year Ford:
LWB & Super Van, 43 gal
SWB Van, 38 gal
Mini Motor Home on Van Chassis, 49 gal
Don't know anything about the quality, but they run around $450 for one kit. Supposedly easy install.
Now I am glad I looked this up for you because I would like more than the current 36 gal capacity on my E350 Motorhome, though not sure I like the price.
Thanks,
Paul
Old 07-08-2002, 10:38 PM
Thanks for the information. I'm not sure that I'm up for the Whitney price. Someone suggested a Bronco tank might interchange. I would prefer to get a tank from the local Pick and Pull lot.
Old 07-09-2002, 08:15 AM
TallPaul's Avatar
I know what you mean about that price thing. $450 is really steep. You may get better/more results if you post this in the Fuel Injection, Carburation and Fuel System forum under Misc Conferences.
Old 07-09-2002, 08:20 AM
swirk swirk is offline
swirk is starting off with a positive reputation.
Fuel Tank Extra Capacity econoplay 1968-2013 Full Size Vans 3 03-26-2014 09:23 AM
Larger fuel tank Chuck the fanatic Modular V8 (4.6L, 5.4L) 2 03-23-2012 01:07 PM
Bigger fuel tank... b_p 1987 - 1996 F150 & Larger F-Series Trucks 14 09-03-2004 06:02 AM
Larger fuel tank? cubman61 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 01-10-2004 02:53 PM
trying to find a larger fuel tank Patch Aftermarket Products 2 06-05-2002 07:07 PM
Tags
2002, 36, e150, fuel, gas, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
