Budd #71410 tubeless Wheels 19.5" 8 lug
Category: Wheels & Tires
Price: $150
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic, '92+ Civic/EL & Del Sol, '06+ Civic/CSX, Prelude, Fit
Item Condition: UT
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
Came off a 1961 or so F-250
These all have the "innie" Hub cap nubs for your original style- type of hub caps
for your 1948 1952 F-2 or F-3 and or other? 1948-1966 etc.
I'm saving another set that I will be putting on a 51 Cabover project that has a GM 3/4 ton chassis (same 8 lug bolt pattern) so I will be able to use these wheels, and have original 51 52 F-2 F-3 hub caps. the advantage for me using these wheels on a COE project as they will help fill in the larger wheel well (fender) openings for a better overall look, at least they way I plan it to look.
So there are lots of potential uses or year and make range of trucks these will fit on.
I've shipped with Fastenal in the past with great results, and reasonable prices.
or local pickup welcome as well.
these come with old tires, or I could have them removed?
located in Salt Lake Utah
PM, me or email at jf m a d s e n at y a h o o dot c o m
or calls ok too 801-694-Eight 8 26
thanks for looking
still have these, the wheels weigh about 41 lbs each or about 85-90 lbs with the old tires on. I can ship these via Fastenal pretty reasonable. just quoted one to Chicago, Milwaukee Wi area for $125. (this was with the tires removed ) for weight
WERNER1
15
06-03-2019 04:20 PM
SoCalAngler
47
09-12-2014 04:59 AM
1964FORDTUF
03-11-2014 10:58 AM
