63 F100 Hood and seat belts - Ford Truck Enthusiasts Forums
Old 08-14-2013, 07:06 AM
sre8212's Avatar
sre8212 sre8212 is offline
sre8212 is starting off with a positive reputation.
New to the forum. Just bought a 63 f100. The truck is relatively solid. Was driving along at about 40mph when the hood flipped up! So couple of things: Not sure how it happened as far as I can tell the mechanism is simple and functioning correctly, I guess it's possible the lever you pull to release the hood was somehow stuck open. Was wondering if anyone has experienced a similar problem. The hood is now slightly misaligned which I will need to fix as it now catches on the adjacent sheet metal when opening. Mostly just concerned that there isn't something I need to check to prevent it from happening again. Appreciate any advice.
On another item can anyone recommend a source for a 3 point seat belt that won't spoil the stock look?
Tilt forward hood kits-Any intersest??? kstones63 1961 - 1966 F-100 & Larger F-Series Trucks 33 09-10-2015 04:33 PM
Hood is stuck shut Primersthebestest 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-06-2015 10:10 AM
Hood won't open Raymond 1999 to 2016 Super Duty 5 11-04-2013 09:53 AM
HELP! '63 F100 interchangeable hoods? Teppanyaki77 1961 - 1966 F-100 & Larger F-Series Trucks 10 10-26-2011 06:53 AM
Hood won't open-HELP 2fords2 1987 - 1996 F150 & Larger F-Series Trucks 0 08-10-2003 09:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
