Learn from my mistake!
Wanted to share another "learning curve" experience when I replaced injector o-rings and reinstalled my injectors about three months ago. At first everything was fine, and then recently I lost power while towing during a long pull, and had large amounts of white smoke. I pulled the injectors and found three of them were scorched, see pic
Comparison between proper and improper injector installation. These o-rings have approximately 2000 miles on them.
Close up with damaged o-ring / copper washer
After asking many boring questions on this forum, and many phone calls I bascially determined this was a self inflicted wound. There are several issues which may have caused this, if not a combination of them all:
1) Injector's not fully seated
2) Injector bolts improperly torqued due to a poor seating
3) Debris, oil, in the injector cups interfering with copper washer during seating.
I spoke with a diesel tech who stated ensure you clean, clean, clean, and clean again the injector cups prior to install. If there is anything small interfering with the copper washer, it provides a path for combustion gases to follow and eventually deteriorates the washer. This is why the symptoms aren't noticed for several months.
Secondly, when seating, smack the solenid of the injector with a rubber mallet and get a good seat. I was timid smacking the solenoid because I didn't want to cause damage. When torqing the injector bolts, tighten them as tight as you can by hand. You will not break the injector brackets or deform the copper washer. He stated this results in about 30-40 ft lbs of torque. Bascially, don't be afraid to tighten it.
On a good note, the scorched injectors are most likely OK and just look worse for the wear. Just need new o-rings and clean up a fine abrasive. I think I'm going to upgrade to Stage 1's now.
Thanks - I plan to do injectors this fall and this is really helpful. But, what do you mean by "tighten by hand". To me that sounds like just your fingers or something. Did you torque it with a torque wrench? Wouldn't that be critical with something like injectors? I'm usually a little lax about getting out the torque wrench, but it seems to me for injectors that would be one where you would want to torque it with a well-calibrated wrench to the exact factory specs.
Probably right. I think the gist of what he was saying is don't be afraid to get those bolts tight, after you seat the injector with a mallet.
I'll give the vaseline a try this time as well. Just ordered my Stage 1's! I definately want to hear them seat this time. I won't be using 30-40 ft lbs of torque either as I'm not in the mood to stretch any bolts, or end up with another improperly seated injector. If I go over 120 nm/10ft lbs a tiny bit though, I'm not going to worry about it.
