Engine identification and general help - Ford Truck Enthusiasts Forums
Old 08-12-2013, 08:45 PM
1966farmracer 1966farmracer is offline
1966farmracer is starting off with a positive reputation.
Hello all. Really glad I found this site. I recently picked up a 66 long bed f100 from a guy in town for $2400. He claimed his buddy built the motor and tranny etc. He said the motor had been bored and had performance parts etc but had no receipts etc. I took the truck out and ran it through its paces. The motor was very healthy, nice sharp throttle response, sounded and felt like a big cam, 3" x piped exhaust, Holly carb, edelbrock intake, electronic ignition, nice firm shifting c-6 with an old school ratchet, spooled 9"
I have a few questions:
I took compression on the motor and came up with 215psi +- 2-3 psi in all cylinders. Seems pretty high?
The motor runs best with about 35 degrees total timing and 12 degrees initial. Seem correct? what would a stock 460 run at?
I know there are certain cylinder heads that are more sought after than other for the BB Fords. Which heads are best?
I know there are better 460 blocks than others, which are best?
What should I look for in the heads for modifications? what are stock valve sizes for the different heads?
Any way to check pistons to see what is in it? scope camera? if so, what to look for.
I would consider myself an amateur gearhead. I plan to change that with this truck. Thanks for the help everyone!
Old 08-12-2013, 09:32 PM
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
First, welcome to FTE!!
Can you give any more specs on the engine?
35 degrees total sounds about right. Not sure about stock specs.
What heads does it currently have? Casting # located between the middle 2 exhaust ports just below the VC rail.
Not sure about the blocks. D0VE-A and D9TE come to mind though. They are all pretty good as cast though, IMO
You can send a camera down the spark plug hole, but pretty much all that will tell you is if they are dish, flat top or dome pistons.
Old 08-13-2013, 06:28 PM
They are DOOVE-C heads. Not sure on any cam specs.
Old 08-14-2013, 05:23 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
probably just D0VE-C heads.
Those are standard passenger car heads used in 70 and 71. SOME people think they are the performance heads but just stock pre-emission heads with 75cc chambers.
The exhaust is the restrive side and benefits greatly with porting (ANY of the 429/460 heads including the CJ and PI heads are restrictive on the exhaust side)
Three issues with my 460 AberrantGenus Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 08-13-2014 11:52 AM
ford 1973 460 crate motor outbackdon 1973 - 1979 F-100 & Larger F-Series Trucks 10 09-29-2010 02:17 PM
351m problem driving me nuts cofecup 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 45 12-19-2009 07:56 PM
460 pinging low compression SuperFord 1987 - 1996 F150 & Larger F-Series Trucks 3 03-12-2009 02:18 PM
Destroyed lifters and cam poorfolks Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 12-20-2005 10:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
