Squeaky Brakes - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Squeaky Brakes
Old 08-12-2013, 08:43 AM
Strokt350d Strokt350d is offline
Strokt350d is starting off with a positive reputation.
Squeaky Brakes
For starters, here are a few problems I always seem to have with vehicles.
1) I don't drive them. Things rust, and wear out very prematurely.
2) On that note, I am very light on brakes. I could go 100k on a set of brakes. I'm pretty much positive I glaze them, and they eventually squeak.
3) When towing, again, light on brakes, but only towing 4k-7k. And not very often either
So last week, my truck was at Ford to perform the tranny TSB. Replace solenoids in trans, reflash computer. No biggie. Brakes have been squeaking for about 2000 miles or so, so I mention it. Guy calls up and says the rears are collecting rust, and killing themselves. Inside rears are shot. So, they decided to replace pads, skim rotors (I would guess some small amount per side just to clean them up), install a Ford anti-squeak kit, and put it all back together. Great, problem solved, right?
They still squeak, and it drives me completely nuts. In my mind, can't you figure out how to get this right? $60k truck should not have squeaking brakes. It's pretty bad too, at least in my opinion.
Now what? Slotted rotors? I have no interest at all at even touching the thing. Not one bit. It shouldn't even be my problem under warrantee.
Thoughts? The Ford "anti-squeak" kit it just a shim of sorts. I know the protocol used to be to put that orange stop squeak stuff on there. I haven't seen anybody use that in years, but maybe that's the trick. Who know. I'm no brake expert, and don't claim to be either.
Old 08-12-2013, 09:57 PM
wht250's Avatar
wht250 wht250 is offline
wht250 is starting off with a positive reputation.
Ive got the same problem. Hope someone here has a solution.
Old 09-23-2013, 05:36 PM
Bjames_F250 Bjames_F250 is offline
Bjames_F250 is starting off with a positive reputation.
Me too.. my brakes squeak intermittenly. Some days are good, others sounds like its time for a brake job. Must be dependant on the outside conditions.
Old 09-23-2013, 05:48 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
What can happen is a couple of this.....if the oem linings are ceramic, they can build up dust on the surface of the lining which can cause the "squeak" and cleans itself when you put on a little pressure. What can also happen is if they (linings/pads) get hot, the shims the oems use are well, minimal...you are not going to like this but, I purchase stainless steel (sheet metal type) scrap and make my own....should be 16 gauge or thinner...and that resolves that issue.
Old 09-23-2013, 07:03 PM
Dave HM Dave HM is offline
Dave HM is starting off with a positive reputation.
I would take it back to Henry Ford and take the head tech on a ride to demonstrate.
my 2012 brakes have never uttered a squeak.
They know what the prob is - I bet
Old 09-23-2013, 09:15 PM
mpoisson mpoisson is offline
mpoisson is starting off with a positive reputation.
Squeaky Brakes
Had the same problem, but alum rims were so hot could cook an egg on them, brought back to the (St)ealer and $800 later complete brake overhaul, calipers, rotors brakes. SA stayed pads jammed in calipers, cooking the rubber boots on the pistons and jamming the bakes on! Not covered under warranty, because brakes pads caused it????? Anyways not happy and calling Ford. TSB AS-21800 reference.
Old 07-02-2014, 07:53 AM
Hey Dave. I agree the know what the problem is, only because they have a Ford Part Number for "Anti Squeak kit"... It's like $14 I think. And in my opinion doesn't work. My brakes are absolutely horrible at this point. Got about 6000 miles on them. I thought they would settle in and stop squeaking, but they just continue to get worse...
I have a friend that own's a shop in town. Been working on trucks for a very long time, and claims to have the recipe to get them to stop squeaking, however it does include new pads/rotors. That's a pi$$er seeing as though the pads/rotors are like brand new, but he says the Ford stuff always squeaks on the 3/4 and 1 tons.
Probably just squeak my way through the summer anyways.
Serpentine Belt Squeak-to-Squeal 94150 1987 - 1996 F150 & Larger F-Series Trucks 15 01-25-2017 04:41 PM
brake issue Jenksie13 1999 to 2016 Super Duty 7 02-24-2015 11:47 AM
2005 2.3l Manual transmission; squeaking at low speeds mmxchamp Ranger & B-Series 7 08-25-2014 02:45 PM
2000 F250 Triton V10 New to me Brakes won't stop squeeking. Merlin Miller 1999 to 2016 Super Duty 1 07-18-2014 08:46 AM
Leaf springs or... 77_F150_4x4 1987 - 1996 F150 & Larger F-Series Trucks 0 02-28-2014 09:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
