89 7.5(460) rev problems
Old 08-11-2013, 08:37 PM
smittybronco's Avatar
smittybronco
smittybronco is offline
I done a 89 model motor swap into my 79 bronco.. The motor runs great no issues but the thing won't rev past like 4800-5000 its like its hittig a rev limiter but the motor was in a running truck before I took it out and it seemed like it would rev to the moon( the donor truck didn't have a tach). Anyone have any ideas what this could be? I've checked fuel pressure and it's spot on, so I do t know
Any help is appreciated and thanks in advance
Old 08-11-2013, 11:21 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,592 Likes on 1,297 Posts
This is a stock '89 motor?
How high do you think it should rev?
If stock, looky here at where peak hp and torque are, and you'll understand that it shouldn't be anywhere near 5000 rpms if it's a stock motor.
Engine_Specifications
"Sound" is not a reliable gauge of rpm.....
Old 08-17-2013, 01:15 PM
97puller's Avatar
97puller
97puller is offline
If it is EFI and you are using a stock computer it is a rev limiter.
Old 08-17-2013, 09:08 PM
smittybronco
I drove it one day cranked it up and it would rev to whatever then I cut it off then it wouldn't go above 5000 after that and that's the only time it's done it
dylansf23
05-25-2015 09:49 PM
SACGNS
06-08-2010 03:20 PM
BRay09
38
11-14-2009 10:30 PM
dallas lewis
1978 - 1996 Big Bronco
02-23-2007 08:33 PM
goodtimesdave
01-21-2007 02:06 AM
Quick Reply: 89 7.5(460) rev problems
