4R70W - real world fluid capacity - Ford Truck Enthusiasts Forums
Old 06-14-2003, 06:42 AM
metrovic metrovic is offline
metrovic is starting off with a positive reputation.
How many quarts did you actually fill into the 4R70W (drop pain, change filter, drain Torque Converter)
the book says something around 13.9 qt dry fill.
Thanks in advance
BTW I'm thinking about buying 13-14 qt of Amsoil ATF for my own vehicles - I hear you can hit 50k to 75k w/ one service interval safely.
Old 06-14-2003, 10:23 PM
kennethl6 kennethl6 is offline
kennethl6 is starting off with a positive reputation.
12 quarts
Initial Start Up Question tigerfan79 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-03-2016 01:20 PM
Mercon V alternative for 4R70w Trans?? tcr1016 1968-2013 Full Size Vans 18 03-27-2016 03:25 PM
Pennzoil Platinum Deal pawpaw Oil & Lubrication 1 08-25-2013 12:58 PM
AOD-E/4R70W problems JJ3 1987 - 1996 F150 & Larger F-Series Trucks 3 04-02-2011 10:30 AM
Havoline and WalMart Synthetic oil ("cheap" synthetics) BrianA Oil & Lubrication 26 11-18-2002 10:27 PM
Tags
4r70w, book, capacity, capicity, change, converter, drain, fill, filter, fluid, ford, qts, time, torque, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
