Donaldson muffler on a 6.0 - Ford Truck Enthusiasts Forums
Old 08-11-2013, 04:06 PM
CPB1's Avatar
CPB1 CPB1 is offline
CPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to behold
I was thinking of putting a muffler on my truck. It came with a straight pipe new exhaust when I bought it about a year ago. It is a 4" down to a 5" the rest of the way and out the back. It is just too loud for me. So I can buy a whole new 4" exhaust with muffler, or I can put a 5" muffler on what I have.
Not many options in a 5" muffler. The Donaldson is really made for a big rig, but I was thinking it may work on my 6.0. I was thinking the M100580.
What do you guys think?
Muffler, M100580, Donaldson - Ryder Fleet Products
http://www.donaldson.com/en/exhaust/...ary/061237.pdf
Old 08-11-2013, 04:15 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
I have been playing around with this. I did a muffler and cat delete last year and the "Jet" engine sound has really been getting on my nerves, so today I reinstalled the cat and it quieted the exhaust down a lot.
Not sure that's a valid option with your 5" exhaust though.
Josh
Old 08-11-2013, 06:03 PM
olemoffat olemoffat is offline
olemoffat is starting off with a positive reputation.
Try a donaldson m100463, flows as much as a straight pipe but will be fairly quiet.
Old 08-11-2013, 06:27 PM
CPB1's Avatar
Josh
Thanks Josh
I was wondering if anyone else thought the jet engine sound was loud. I could not hear my Chevy half ton running next to the Ford, and it was only idling.
It gets real loud at about 2k RPM under load. Kinda cool, but gets on my nerves after about 30 minutes.
Next problem is clearance, not sure how tight it will be.
After looking at it again, I could get on the 4 inch section pretty easy. This gives more muffler options. Any suggestions?
Old 08-11-2013, 07:36 PM
Bullitt390's Avatar
The jet sound doesn't bother me too much... But I rented out my house and moved to an older neighborhood in the city and I know it drives my neighbors nuts in the morning starting the truck and making my way down the street.
So, basically my conscience is coming out. Re-installing the cat made the exhaust a lot quieter but almost too quiet.
Josh
Old 09-14-2013, 10:18 PM
CPB1's Avatar
Update: It fits
Well it does fit, but it was a squeeze. I had to do a lot of pushing, pulling, trial and error. I have it all the way up to the crossmember. I used stepped band clamps and they worked great.
It is definitely not loud now. With the straight pipe it would drone real bad at low rpm. It also got real loud when it hit 2k rpm, kinda like a race motor. I still have a slight drone at low rpm, but the high rpm noise is gone. I can rev it out and get all power and no noise.
I went with the Donaldson M100463.
Old 09-14-2013, 11:38 PM
lupuseven's Avatar
lupuseven lupuseven is offline
lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.
awesome thanks for sharing
you never know when someone might want to do the same but is afraid to be the 1st, or tackle with out some advice.
Old 09-15-2013, 08:42 AM
CPB1's Avatar
No problem.
I don't think this is the best choice for exhaust options, but considering what I already had on the truck, in my case it may be.
The only problem I see so far is the front of the muffler hangs a little low, and where it ended up is right in the middle of the truck. It's very vulnerable to getting ripped off the truck in off road situations. Other then that I am pleased.
Old 09-15-2013, 07:20 PM
ul37's Avatar
ul37 ul37 is offline
ul37 is gaining momentum as a positive member of FTE.
MBRP makes a 5 inch muffler. Got one on my truck with no cat. Not load at all.
Muffler for my 4" Flo-Pro??? 06greenstroker 6.7L Power Stroke Diesel 8 01-21-2017 06:15 AM
MBRP muffler is too loud, two mufflers? spdmpo 6.0L Power Stroke Diesel 15 09-05-2015 07:06 PM
Donaldson oil filter Supercab 1999 - 2003 7.3L Power Stroke Diesel 21 04-09-2012 06:29 PM
Donaldson Cold Air Intake? cmdevildog16 6.0L Power Stroke Diesel 3 05-17-2011 04:45 PM
Help 6.0 Excusionw/exhaust drone?s amdc5c5 6.0L Power Stroke Diesel 4 03-03-2007 09:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
