after driving around for a little my hood comes up a little in the rear , does the mean that i can replace just the springs ? or do i need to replace the total hinge ?
Mine did the same, tried every alignment many times. Even followed Ax's excellent post here twice from scratch. Could get things aligned decently but passenger corner would pop up after a short drive. Recently installed the tilt front kit from Mid Fifty and could not be happier with it. Everything lines up perfect and so much more room to work under the hood. Changed my header gaskets and cleaned plugs today in less than an hour. No way I could have done that without the tilt hood.
That's funny Ax, I was thinking the latch and/or catch is worn, so move the latch back! Oh well, try Ax's way first, if that doesn't help, move the latch back a bit from where it is now. Note: make some marks around the edges so you know where you originally started. And then go buy that tilt kit! Good luck, Jag
hey ax and guys ,, been a little out of it lately, but i am back working on my truck ,,i am ready to try the hood latch adjustment,, so you are saying move the catch forward a hair ??
Try and see, might be difficult to move it 1/8". Also all the hinge pivots, especially the hidden one must be free and operating smoothly. DON'T try to wind up the springs, sure way to ruin them!
