TCU
08-11-2013, 09:23 AM
on
TCU
After driving truck all day when I turned the truck off it would not start. I have jump the started and it will start and run but will not shift, no speedometer, no tow haul light. and only stays in 2nd gear. I suspect a relay problem in the TCU.
08-11-2013, 06:30 PM
Do you have any information about the truck? Year?? Engine? Anything?
08-11-2013, 07:54 PM
Eh... Ford doesn't use anything called a "TCU".
08-12-2013, 03:58 AM
I thought this was going to be about Horned Frogs.
08-12-2013, 11:06 AM
Quote:
Originally Posted by
RPM371
+1
08-14-2013, 06:08 AM
on
Mark Kovalsky
2003 F-350 diesel. Automatic 4x4.
08-14-2013, 08:11 AM
A 2003 F-350 diesel Automatic 4x4 could have either a 6.0L or a 7.3L engine. The systems are VERY different between the two. Which one do you have?
08-14-2013, 10:37 AM
08-15-2013, 09:12 AM
on
I have the 6.0 but now has a cummins 5.9
08-15-2013, 09:27 AM
Great! Now we are finally getting close to what you're running. The stock Ford TCU will not work with a Cummins engine. What type of TCU do you have in it now?
08-15-2013, 09:32 AM
on
08-15-2013, 01:34 PM
This is the best thread that I've seen on FTE in ages!
There isn't even a question in the original post.
08-15-2013, 03:30 PM
on
found a blown fuse #22 under the dash I will start there but need to buy a 20 amp fuse
08-16-2013, 06:20 PM
I don't think a PCS controller can control a TorqShift transmission. I know that they say it can, I'm VERY skeptical of that claim.
6.9idiatsturbo
04-19-2012 09:06 AM
F2502011
6.7L Power Stroke Diesel
01-24-2012 06:55 AM
wattsup
1997-2006 Expedition & Navigator
01-08-2012 05:43 AM
Lane Jason
1999 to 2016 Super Duty
02-24-2008 07:25 PM
wickymustang
09-16-2004 08:14 PM
