EGT sensor/no regen
EGT sensor/no regen
Morning,
I have a 2008 6.4 with 168,000KM & about 1 month ago I pulled a code P2084 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 2.
I pulled out the sensor it was very dirty, I cleaned it up and put it back (ford recommend). After cleaning the sensor I still had the error code so I deleted it and haven't had a check engine light since.
My question is: I have not gone into regen since, and is it because the sensor is gone and needs to be replaced? And will this effect my fuel economy?
I am new to the diesel world and some of this newer technology so any help will be much appreciated.
if my conversion is correct 200 liters is like 53 gallons so if your getting better than 11 mpg or 4.67658KM/L you have not driven far enough to hit the fail safe regen
When I had a DPF (not too long ago), I would Regen at least once per tank (about 25 gals). Even if I was doing pure highway driving. He's gone through double the amount and still nothing. I would start getting concerned that something wrong too. But if DPF gets real clogged, and your sensors aren't telling it to regen, then I would think some sort of back pressure code would occur. Keep an eye on it.
Thanks for all the replies, I am getting concerned because I haven't seen a regen in a month or so and honestly not since that sensor code came up. I have been keeping an eye on it and have not see a "fail safe" regen ethier.
I'm starting to think that sensor is bad, anyway to test it? I don't want to throw parts at my truck but it seems like a coincidence once that code came up I have not seen a regen.
I know this doesn't answer your sensor question but I agree with the recommendations of the GSchretter above. Get a monitor, the Edge Insight CTS is just that and it permits you to watch a lot more vitals than the simplified gauge cluster on your dash. It isn't a tuner so you don't have to worry about warranty issues. It's a bit pricey, ScanGauge makes a monitor that does almost the same stuff, just with less fluff than Edge's product and its quite a bit less $.
Back to your regens concern, can you tell us how many miles (or kms) you've driven since you believe you had the last regen, that way we don't have to guess or calculate with assumptions about your fuel economy?
