aFe to RiffRaff filter
Hey just thought I'd share some photo's of the filter conversion from an aFe stage 11 style filter to the RiffRaff 6637 filter kit.
aFe set up , this filter is very small compared to the RiffRaff 6637
Battery box and air box removed
This is roughly how i will set the filter up
The original battery / air box i cut in half, and just have the front battery compartment and intake panel.
Made a new adapter plate for the intake tube to go through, this will bolt to the side of the battery box side panel.
This is how the plate looks fitted up , it holds the filter steady.
Fabricating a new bottom for the filter.
Spot weld and check for fitment.
Fit a panel to separate the battery and filter for the battery.
First test fit, had to make some adjustments around the power steering piping.
Filter elbow tack welded to the new intake panel.
Ready for the paint shop.
Painting in progress.
Filter elbow.
First fitment after painting.
Side of the new filter box , with the elbow in place and intake tube.
Ooops forgot the hole for the filter minder, welded in a 1/8'' 316 flat washer so the grommet will fit snug.
Fitted up , make sure everything is clear , notice i fitted the sensor on the back of the filter box , i did this just because it was there , RR instructions says to cable tie to the wiring loom.
Try the filter minder .
Fitted up and make sure there's clearance all round the filter.
I did some research o how the filter minder should be fitted and found that there shouldn't be to much length between the tube and the minder , so this is why i fitted it like this.
Finished product.
Now for the test run.
Filter elbow.
Finished product.
That other riser is for filling the add on water to oil cooler for the transmission, i had some heating issues with the tranny some time ago so i fitted an extra W/O cooler under the truck.
W/O cooler and 12 volt pump sit on the T/C xmember.<br/>The filler neck is just to keep this topped up.
Make yourself up a simple boost leak tester out of pvc pipe
then test for leaks, you will need a spray bottle full of soapy water to spray over the ic pipes and basically any where that air from the intake can go.
Have you a chip or tuner?
What wait are you towing?
Fuel pressure?
Fuel pressure?
