Can a 4.6L MAF sensor be used on a 4.2L? - Ford Truck Enthusiasts Forums
Old 08-11-2013, 06:35 AM
99'F150owner 99'F150owner is offline
99'F150owner is starting off with a positive reputation.
Hey guys, i really need some help with my truck, really rough idle, it shakes out of control and misfires. The diagonostics from autozone says its the MAF sorry dont have any codes.I bought a used mass air flow sensor for my 1999 F150 4.2L V6, but got the wrong one, ended up with one for a 99' 4.6L V8 model. Can not return! Can a 4.2L V6 mass air flow sensor be replaced by one belonging to a 4.6L V8?
Old 08-11-2013, 07:57 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
It's not the MAF sensor!
You likely have the common vacuum leak in the PVC valve elbows.
Old 08-11-2013, 08:35 AM
Could the vacuum leak be responsible for the rough idle, constant shaking and high gas consumption? Thanks alot for your reply, really appreciate the help
Old 08-11-2013, 01:42 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
MAF:
The sensor measures a small percentage of the airflow through a sample passage.
It is calibrated for the engine size and fuel injector size the PCM has in it's program.
A 4.6 may run the motor but is not the correct calibration.
MAF is not the source of misfires.
Misfires are a lack of uniform cylinder combustion pressures.
MAF only measures the amount of airflow.
Diagnose correctly for the fault.
A the present time you have no stated info to that effect.
Good luck.
Old 08-11-2013, 08:50 PM
Quote:
Yes. Otherwise, I would not have said to check that and would have just let you waste your time and money screwing around with MAF sensors.
Old 08-12-2013, 12:22 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Although it may not help your mechanical issue, looking on RockAuto's site, depending on brand name and part number, it looks like some MAF sensor versions may fit 4.2 and 4.6 engines. Check the brand name and part number of the unit you bought with Autozone or other retailers that may sell the same product if you haven't already. The numbers will have to match.
MAF MASS AIR FLOW SENSOR F5UF-12B579-BA delosocristian 1968-2013 Full Size Vans 0 06-10-2013 09:18 PM
Mass Air Flow Sensor for 99 F150 policedutchdog 1997 - 2003 F150 12 05-10-2008 08:23 AM
2006 4.6l Maf jcarlson Modular V8 (4.6L, 5.4L) 2 03-20-2008 10:30 PM
MAF and Power Steering Pump duggyb 1997 - 2003 F150 1 06-08-2007 02:04 AM
Airaid intake kills mass air flow sensor rleptrone 1997 - 2003 F150 5 12-20-2004 07:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
