My 6.2 trip report
My 6.2 trip report
The truck had 870 miles on it when we left and 2900 when we returned, 1600 of that was towing and the rest was mixed city hwy. The truck and trailer scaled at 24340 lbs ready for the road.
The first 800 towing miles was almost all interstate with some wind all from the side or head on we averaged 8.5.
The return 800 miles was mostly 2 lane with a lot of small towns and hills and some wind again side and head on we averaged 8.
Mixed town and hwy we averaged 12.5 and the little hwy empty it was between 16 and 17.
I was trying different ways of driving so I think I can improve the mileage over time. Some of the hwy was with DW driving and I can always get better mileage when I drive (but I didn't really say that).
The 6.2 never missed a beat and with 2900 miles on it the oil is down 1/8 on the dipstick. After the 6.2 adapted to towing it really came alive and had no problems pulling our trailer, we even spent most of our time in 6th gear when on level road without heavy winds, with 17" tires 4.30 gears it ran the best at 65 mph and 2K rpm in 6th.
The 6 speed took awhile to figure out; when pulling I liked the standard mode over the tow haul, I just don't like the way the tow haul holds in gear but I do like the way in brakes going down hill in tow haul, I think the manual position will also work out well going down grades and I will play with that this fall when we are in the mountains. If you really want to get it moving pulling the manual shifting works the best, I tried it a few times when merging on to interstates. Overall pulling I like the way it shifts but it does get a little sloppy when its been run around empty but I can live with it, it really firms up after pulling a short distance and the shifts are smooth but firm with the gear spacing very even all the way to 6th. Overall the 6.2 and the 6 speed empty seem a little disconnected but after pulling they work together smoothly. We did pull one good hill coming out of Taylor Falls MN and after getting behind a slow semi I pulled out and this thing had no problem gaining speed up hill using 3rd and 4th gear, I was impressed.
Everything else on the truck worked out great with the only problem being the voice commands for the navigation system, we just don't get a long very well.
Denny
Denny
Congrats, sound like a great tow experience. I was wondering how it would tow compared to empty weight of the truck and would agree it does seem to be off a little when running around with nothing in it, I suppose that some dead weight in the truck might help it out. Not to shabby mileage either. Good to hear that over all it can hold it's own pulling a load like the V10.
Good report and thanks, I'm moving up to around 12,500 pounds of fiver so with my 3.73's I doubt I'll ever see 5th as I never see 6th now but should be able to handle it. I'm always above 5000 foot altitude so down on power from you lower altitude guys so thinking about a CAI and 5 star tunes.
I tow with tow/haul engaged on cruise with 6th locked out and manually lock out 5th and 4th as needed. I too realize the Ford transmision guys believe this engine has more midrange than it does. I've learned what hills it's going to pull in what gear so as I first start up a hill I lock out 5th and if necessary 4th forcing it to down shift before loosing speed. Once on the hill I allow 4th and 5th and let it decide when to grab them. I do this because it resists down shifting but once there will stay put and not upshift till well over the crest. My over all mileage towing my 7000 pound RV and hauling my 1000 pound RZR in the bed was 9.1 at mostly 60 mph. This was a 800 mile round trip from Cheyenne to Clark Wyoming (north of Cody).
Jeff
Jeff
We will be heading west after labor day so I will find out how the 6.2 handles the higher altitudes, our first test will be Wolfcreek pass. I kown I plan on using the manual shifting in the higher elevations to keep the motor in its power band, from what it felt like on our first trip it won't have any problems handling anything we have planned for it this fall and winter.
Denny
Denny
Jeff
Aaron
Denny
Denny
The down hill side of the pass,
For those that fly by the signs,
if you are in 2nd or 3rd with 3:73's or 3rd or 4th with 4:30's whats the difference?
Denny
Ask yourself this, has that engineer ever pulled a heavy load up the side of a mountain and what about the long term affect of wear and tear on the transmission, with 4.30 gears you have less stress on the transmission because of the mechanical advantage they have over the 3.73 gears.
Denny
Denny
Jeff
Denny
