Any Pics of 3" Lift w/35.12.5/20 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 08-10-2013, 10:54 PM
Zooki1 Zooki1 is offline
Zooki1 is starting off with a positive reputation.
Would like to see any pics if you have a 3" lift w/35.12.5/20 wheels and tires. And has anybody had any issues/problems with this setup? Sorry...and I meant to say on a 2011
Old 08-11-2013, 12:02 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
You don't need a lift for 35x12.5x20. Factory 20's are 34.2 in height and 11.5 wide, so it's really close. Also check out Toyo, BFG and Nitto's 295 width series.
Old 08-11-2013, 12:26 PM
Quote:
Sorry quess I should of gave a better desc. I currently have 275/70r/18 on a 2011 F250 4x4 crew cab and am thinking of going with 20x9 wheels with Nitto Terra Grapplers 295/60R20. And I thought a 3" lift would look good with this combination so I was curious if anyone had some pictures of this setup or close. Any photos or input would be appreciated..Thanks
Old 08-12-2013, 01:16 PM
ccstp's Avatar
ccstp ccstp is offline
ccstp is gaining momentum as a positive member of FTE.
Lil bigger than what you were looking for. Hope it helps though. 4.5" lift. 37x13.5 Toyos
Old 08-12-2013, 01:58 PM
Amelio's Avatar
Amelio Amelio is offline
Amelio is gaining momentum as a positive member of FTE.
I also plan on the same thing.....Ready lift has a 2.5" lift that goes right in for our gassers....there is one member that has it and its just the right amount of lift IMO
Old 08-12-2013, 03:50 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
3" may make it more susceptible to pointing to the sky with anything in the bed and/or a trailer hooked up to it.
I have a 2.5" readylift kit with 35s (on 18's though). Pics in the thread below:
http://www.ford-trucks.com/forums/11...ll-thread.html
Old 08-12-2013, 08:14 PM
Quote:
That is one nice looking trk, thanks for the pics....what brand of lift did you use?
Old 08-12-2013, 08:21 PM
Matt,
That is a great looking trk also...I originally was looking for the grey but couldn't find what I was looking for. Just curious why you said the 3" might make it more susceptible to pointing to the sky?
Old 08-12-2013, 08:24 PM
Quote:
Amelio..do you remember who the member is? Is it Matt (silver bullet)
Old 08-13-2013, 04:09 AM
ccstp's Avatar
Quote:
Thanks bud! It's an ICON 4.5 stage 1
Old 08-13-2013, 06:56 AM
Matt,
Are you installing taller blocks in the back too? If not, raising the front that much might have it sit higher than the rear (especially if you have a 250 as they're almost level stock). Anything you put in the bed would have you sitting like a pre-runner truck (exaggerating, but you get my point).
Old 08-13-2013, 07:38 AM
Ok now I get why you said that....I would do a 3" all the way around..yeh I agree with you, on if a person only put 3" in the front. Thanks for the input. Im new on here and I figured I would get more responses than I have
Old 08-13-2013, 09:41 AM
Amelio's Avatar
I had to look in a previous conversation....the member is "RAPR" He actually did a 3.5" lift which is what is made for the 6.7.....I beleive he had to change his front drive shaft to make it work though.
I am not interested into getting into that much work....he suggested the ready lift 2.5" its a straight bolt in......I think it will give me just the right amount of lift for what I am looking for.....I then plan to get some pocket style flares and run some 35"s
Its a lil ways of cause the wife says I gotta wear my stock tires down first and seeing how I have only put 8600 miles on my truck since I bought it in December its gonna be a while
Old 08-13-2013, 06:34 PM
My wife said the same thing ("What's wrong with those tires?!?!" They'll never get it....), so I just aired up to Ford's recommended psi and had some fun skating around on them empty. They'll wear out quickly at that rate, trust me...
Old 08-13-2013, 08:24 PM
Worbly Worbly is offline
Guest
Worbly is starting off with a positive reputation.
Hopefully I can post up pics of my f250 with a 4.5" lift and 35x12.5x18R this weekend. She goes into the shop tomorrow to have a Carli pintop lift put on.
Do I need a Lift Kit? Oscar Hernandez Jr. 1999 to 2016 Super Duty 1 09-02-2016 05:08 PM
Anyone went from 325/60/20 to a 35/12.5/20? Haydendh 1999 to 2016 Super Duty 6 04-12-2016 08:05 AM
Where can I get 36" 12.50 20 tires? Xv10 Excursion - King of SUVs 4 04-21-2014 04:39 AM
New Fuel Offroad Tires Installed 04XLTRUNNER 2009 - 2014 F150 13 02-11-2014 08:30 PM
35/12.5/20 on 96 f350 how much lift? fordboy2 1994.5 - 1997 7.3L Power Stroke Diesel 10 11-07-2009 07:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
