1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Instrument Cluster HELP
Old 08-10-2013, 06:02 PM
FordFinatic157's Avatar
FordFinatic157
FordFinatic157 is offline
I have a 2001 F350 and instrument cluster lights will not work. Fuses are good and the gauges still work just not the lights. Any Ideas? Thanks in Advance!
Old 08-12-2013, 04:54 PM
memobug's Avatar
memobug
memobug is offline
Do you mean the backlights on the gauges (with the nighttime/headlight illumination) or the idiot lights?
Regards,
Matt
Old 08-12-2013, 08:16 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Check the illumination circuit to and off the dimmer control. I guess it wouldn't hurt to actually try adjusting the dimmer....
Old 10-05-2013, 03:45 PM
FordFinatic157
The backlight of the gauges do not work. I have already replaced the headlight switch and made sure the dimmer was all the way up. The backlight for the climate control also does not work, so i think they are both tied into the same circuit.
Old 10-05-2013, 07:36 PM
projectSHO89
You're going to need to get a meter out and make some checks at the headlight switch to see what's going on. You've already reached the limit of guessing.
Old 10-05-2013, 09:35 PM
memobug's Avatar
memobug
memobug is offline
The steering wheel illumination, radio light dimmer, 4wd mode switch illumination, climate control and instrument cluster backlight are all on the same circuit. Since you lost the climate control backlight, it's probably not the ground side.
The hot side is all wired up to the pulse width dimmer module which gets its power from the headlight switch. It's very likely either you aren't getting 12v to the dimmer module from the headlight switch, the module is bad, or its output is shorted to ground somewhere
Regards,
Matt
440 sixpack
11-16-2018 08:36 PM
Jobo57
06-02-2014 02:30 AM
Ole Green 1978
02-09-2012 07:55 PM
Like M. Fords
Electrical Systems/Wiring
06-06-2004 03:47 PM
Quick Reply: Instrument Cluster HELP
