1993 F150 Clutch Collapses ???
My son has a 1993 F150 4.9 5 Speed. Randomly the clutch pedal collapses to the floor and fails to disengage fully. It has to be pulled back up and then functions perfectly until the next time it randomly sticks/collapses ... It is a hydraulic clutch and full of fluid. I did notice that the rubber diaphragm inside the master cylinder is extremely swollen. I know this is typical of having the wrong fluid put in the system ... not sure what I should do now ... any suggestions? Clutch feels great and functions perfect 90% of the time?
Thanks for any input/advise!
First thing is to carefully check for fluid leaks in the hyrdo system.
Second, it sounds like you may have an actually pushrod or pedal assembly issue. If there is something wrong with the pedal itself then this could happen. However if there is a fluid leak, you can search all day and it will collapse until the leak is fixed.
Leaks
Thanks,
DSparksF250
11-07-2016 11:06 AM
keyul
07-12-2013 03:18 PM
IDIDieselJohn
12-14-2010 08:07 PM
bozo4ford
06-02-2005 05:37 PM
