ABS light on, growling brake pedal - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-10-2013, 11:15 AM
gears351's Avatar
gears351 gears351 is offline
gears351 is starting off with a positive reputation.
Ok, 116k miles, new brakes (6k miles ago) and now the ABS light comes on, the pedal growls & vibrates and it doesn't want to stop like it used to. First real problem (other than a ghost tailgate opener) on my 07 Exp EL -
It sounds like the pads are gone so I pulled the wheels and the rotors are clean and smooth and the pad friction material looks brand new (inboard & out, front and rear). When braking the growl comes from the firewall by the pedal, the pedal jounces around and the truck takes a bit longer to stop - sometimes the ABS light is on sometimes it's not.
Searching the forum I think I'll try building a shield around the tone ring pickup on the steering column (there's a TSB about this) but I was wondering if the truck's diagnostics would tell me the ABS code or if I need a dealer to scan it for that.
Is there something common that goes out on these trucks that would cause ABS problems?
Thanks
7.3L IDI w/turbo Growling Noise pascalhorse Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 08-16-2012 11:07 AM
ABS issue on 2005 XLT KYMEDIC 2004 - 2008 F150 3 10-09-2011 11:36 AM
ABS Problem MikeVT Explorer, Sport Trac, Mountaineer & Aviator 0 06-12-2010 11:22 AM
brake issues. green 69 1999 - 2003 7.3L Power Stroke Diesel 0 03-08-2010 04:30 PM
Intermittent brake problem Eric K 1999 to 2016 Super Duty 7 08-04-2007 08:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
