What are the Best Power Programmers for 6.0L's
Neither. You need to get an SCT programmer for your 6.0. Bullydog causes PCM problems and Edge is under the gun from the EPA.
Contact this guy: Gearhead Automotive Performance
Received 5,160 Likes
on
SCT is NOT a "chip". It's a flash programmer that you plug in to the OBDII port. You can use the included tunes or custom tunes FOR YOUR VEHICLE as previously mentioned. SCT is head and shoulders above anything else for a 6.0. Period.
I have the Edge CS (purchased like 2 years ago) & the Tune's seem to work good but I dont have experience with any others.
I hear BullyDog are the worst for your Transmission, seems as if lot's of people like the SCT.
Thought about trying 1 myself but since i have the Edge (which works good) I havent talked myself into changing.
With the Edge I can see absolutely every bit of vital info imaginable (U need to buy the EGT Probe separate), its expandable for any additional sensors u may want, u can correct your Speedo for oversize Tires & it has a Diagnostic (code reader) feature
on
I think you meant SCT. The SCT tuner can be bought individually or you can save yourself a step and just buy the tuner from Matt at Gearhead Automotive Performance . Scroll up to post #2 and there is a link to the Gearhead website that npccpartsman posted. Click on the link and get ahold of Matt and he will set you up with everything you need, SCT tuner and custom tunes of choice.
I pretty much agree with this myself. I get a little better mileage with my tow tune, but It'll take a long time to offset the cost of the tuner itself. The biggest advantage to using the tow tune is how it shifts. The tranny holds in overdrive through rolling hills, where stock tuning would have it downshifting going up mild grades.
