HELP!!! ELECTRIC FAN SWAP!!!
Hi everyone! I have 96 F150 4.9 6in lift 2wd for now...soon it will be 4x4...anyway I need this truck to cool down! I live in Southern California so it can hit 120 degrees. I put the larger radiator in it but of course the fan shroud doesn't fit...what electric fan/fans can fit in this truck? The small stock radiator sucks...also new engine only 5000 miles on it...
I have yet to do my bronco but here are a couple I used to get the parts together:
Electric Fan install. 1989 460 EFI - FSB Forums
Electric Fan Install on an 86 Ford Bronco - FSB Forums
X2 12" Push Pull Electric Radiator Slim Fan Kit Honda Nissan Toyota Mazda Acura | eBay
I personally purchased those fans and they work awesome. Easy to install, and they are very slim you have plenty of clearance between them and the engine.
A 302 in an f150 requires 2500cfm to cool properly. The BEST oem electric fan to use is the 3.8 taurus fan. you can google it, they are the best. A good aftermarket install would be 2 of these fans like i used. http://www.ebay.com/itm/BLUE-12-UNIVERSAL-SLIM-FAN-PUSH-PULL-ELECTRIC-RADIATOR-COOLING-12V-1730-CFM-NEW-/140806010029?pt=Motors_Car_Truck_Parts_Accessories&hash=item20c8b134ad&vxp=mtr
they are 1700fm each so that should be more than enough for your 4.9. i am using them on my 5.8 also.
here is my install
https://www.ford-trucks.com/forums/1...with-pics.html
here is my install
same here. they are really great fans for the price. if you wanted to improve the cooling, you could even make a shroud and mount them 3 inches away from the radiator. i will do this when my big radiator comes in,.
a less efficient fan WITH a shroud can do better than a more efficient fan WITHOUT a shroud. shrouds help the entire radiator get cool air instead of a small circle in one spot.
those fans would work well because they are built into a shroud. one is for AC on and the other is run by temp. you could run them both at the same time and get some good cooling. i dont know how much CFM they are.
