No power to 1 rear door lock and window - Ford Truck Enthusiasts Forums
Old 08-09-2013, 11:03 PM
hellmary hellmary is offline
hellmary is starting off with a positive reputation.
I have a 1995 F350. The passenger side rear electric door lock & electric window does not work. All 3 other doors work fine. Also the light in the door works when opening the door, but nothing else in that door works. Any help would be greatly appreciated.
Scott - Surprise, Az
Old 08-10-2013, 07:23 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Sounds like your lock actuator is bad(common problem)
Also sound like you have a broken wire to that window(common where the wire goes from the cab to the door)
Crew Cab Rear Door Power Windows Crewcabber 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 03-31-2015 07:18 PM
Power windows, locks, mirror not working Black 07 2004 - 2008 F150 1 06-01-2012 05:13 AM
2000 Ex electric doorlock problems sandaholics Excursion - King of SUVs 10 10-26-2011 10:22 AM
2000 Excursion electric window/door problems 2000 X Excursion - King of SUVs 1 10-24-2011 11:53 AM
Rear Hatch Not Locking.......Did Not Know DSMMH Excursion - King of SUVs 12 03-08-2010 12:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
