maybe someone can give me a lead here:
I have to crank the truck several times for quiet some time, until it starts. Once started, no smoke, smooth running and lots of power.
I shut it down.. wait 5 minutes, and have to crank it for a long time again..
mods that i just completed:
auto to 5 speed swap, new baby swamp injectors, rebuild turbo, new exhaust , straight pipe from turbo back. E-fuel.( have set at 70psi and switched through relay. runs as soon ignition is on, as well as during cranking).
I do not have the A&E enhanced package for my PC, so i can not read any kind of data.
You bet. That should wake the truck up and run quite nice with that combo. You pull much and you're gonna want to upgrade the hpop if its still a 15. A stock 17 out of a SD would work fine. I think it will struggle to keep up with your other upgrades pulling a good load.
Update.. drove the truck today. after several miles and several start of the truck, she now starts much better
thanks for the help guys.. that was an easy fix
I had the same thing after I replaced my fuel pump. Freaked me out. It ran so bad at first I thought I had totally screwed it up. My friend told me to drive the snot out of it and see if it helped, so I was screamin all over the countryside for about 30 miles. Ran great after.
Might want to check your batteries... 7.3's will not start with less then 10.5 volts while cranking. I would rent a load tester from autozone and see if they check out.
luckily all im pulling is the whole 3000lbs of my airstream
the HPOP is still stock.. i would replace it with a superduty one, if i could find one :-) (cheap that is)
If you go to the Super duty section you may be able to get a 17* for free.
When they want to upgrade their HPOP they need a core... your 15* can be a core for them and they can send you their 17*.
I know a few members have done this and gotten a free upgrade.
