I want 40's
I want 40's
Sorry if there is already a tire fitment guide or similar post but im going nuts trying to figure out if 40's will fit on my crew cab or not. i think they will but im not sure. it has 9" of lift, 6 suspension and 3 body. no shackles or anything fancy like that, just springs and body lift. it has military 37's on it now and dwarfs them, but they run small (around 35 inches). i would like to get a set of 16/40-16 Super swamper LTB's and mount them on 16x10 steel wheels, 4 inch backspacing. im sure id be safe with 38's but they dont make the ltb in that size for a 16 inch wheel. those are what i want, very agressive and cheap. dont drive the truck that often either. i can get some wheel spacers if i need to also. so what do you guys think, any info or pics would be appreciated. id post a pic but im not sure i can.
Thanks Jake
Thanks Jake
Ok i think i finally figured out how to post pictures. this is the only one i have on my computer at the moment. you can see how small the 37's look (but they are really only about 35" tall) this truck is mainly just used for cruising, its a little long to do any real wheeling with, plus its just to straight for me to bash up, i really dont want to trim any sheet metel either, maybe cut out fender flares but there some $$. i will definatly get some spacers to keep the tires away from the frame if needed.
