power steering question 1979 f250
Old 08-07-2013, 08:59 PM
blackgate99's Avatar
blackgate99
blackgate99 is offline
so i have a 1979 f250 custom, and last night when i was starting to park my steering wheel was hard to turn like a hard spot in it (i.e. it was hard to turn like the wheel was stuck) so i drove it around today and the problem is still there, im wondering is my power steering going bad or does it need new fliud, its not squeaking but its hard to turn on both sides, if i need new fliud any idea what im supposed to put in it, and if i need a new ps pump what part should i get, any info would be much appreciated
sincerly Andrew Hudson
Old 08-07-2013, 09:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
First, check and make sure the belt is good and its tight. These trucks use transmission fluid for the power steering.
Old 08-07-2013, 10:02 PM
blackgate99
ok so im not going to lie, i grew up in a family of mechanics but im a geek and spend all my time learning about computers, which belt am i after (if you give me the name i can probably look it up in the owners manual) and i have the tools to tighten if need be, and they use transmission fluid, humm interesting
Old 08-07-2013, 10:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check the illustration. In the upper left is the power steering pump, the circled ABC kinda point to the belt.
File Type: pdf
Old 08-07-2013, 10:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's a kinda crappy picture. The power steering pump is inside the yellow square.
Something else to check, make sure its full of fluid too.
Old 08-07-2013, 11:26 PM
blackgate99
the belt is loose, so is that causing my steering problems, and thanks for all the help so far
Old 08-08-2013, 03:47 AM
psychlopath's Avatar
psychlopath
psychlopath is offline
Well, it could be causing it, if it's allowing things to slip when you put some strain on the pump. Tighten it properly and find out.
While youre there, check the fluid level inside the pump. There'll be a little dipstick on the cap of it.
MyBabyCopper
12-12-2012 10:53 AM
o'brien
09-17-2007 01:23 PM
liljase
15
04-15-2005 08:44 AM
Quick Reply: power steering question 1979 f250
