Should my boost be higher than 20psi? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-07-2013, 03:38 PM
Groundpounder0331 Groundpounder0331 is offline
Groundpounder0331 is starting off with a positive reputation.
Note the mods in my sig line below. The most boost I can generate is 20psi, and that's at the top of the power band, screaming up a mountain pass with a 9K trailer, driving with EGT's at 1200. Is that the max I can get without further mods, or should I be creating more? If so, should I be looking for a leak somewhere?
Old 08-07-2013, 03:47 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
That's it. If you have a Cali model you should be around 28
Old 08-07-2013, 03:48 PM
fordpride's Avatar
With a completetly sealed system I could get 23psi
Old 08-07-2013, 04:10 PM
Ok thanks. I saw others were getting higher boost with relatively the same mods. I do think it's time for Stage 1's and an interooler. Maybe a new HPOP... Let the fun begin.
Old 08-07-2013, 06:33 PM
madMatador78's Avatar
madMatador78 madMatador78 is offline
madMatador78 is gaining momentum as a positive member of FTE.
Highest I ever saw was 23 and I thought my truck was stock. However I just found out I have an SD compressor wheel in my turbo, which makes me wonder what else has been done to it. also running an edge programmer in the lowest steering.
Old 08-07-2013, 08:16 PM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
I get 20 and not a tick more. no exh leaks and what seems to be a well running psd.and yea thats just flogging molly and up top in the revs
Old 08-07-2013, 08:38 PM
Just curious, could wherever the gauge is hooked up effect readings for good or worse? Or is it pretty much ok wherever.
Old 08-07-2013, 08:39 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
What position is your chip in?
Old 08-08-2013, 09:42 AM
I'm not the expert here, but when I hooked up my boost guage, I just found the most convenient location and did it. This was on the passenger side of the motor, and it worked fine. I don't believe location makes a difference.
Old 08-08-2013, 12:44 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
It will make a difference if you have a intercooler, otherwise just put it where ever.
I could hit 23 psi with similar mods except no chip.
Old 08-08-2013, 01:24 PM
richdawg's Avatar
richdawg richdawg is offline
richdawg has a good reputation on FTE.richdawg has a good reputation on FTE.
I am just wondering how ya all are testing for boost, and is everyone posting here testing the same way? I don't have a boost gauge and am just using a pressure gauge. If I am just romping on it going on the freeway in forth gear it jumps up to 30 or a little more and then about the same when I go to 5th. this is with no load and no inter cooler. When I am towing I don't think it gets that high though.
Old 08-08-2013, 01:36 PM
WADE MMT/PSD WADE MMT/PSD is offline
Former Vendor
WADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputationWADE MMT/PSD has a superb reputation
I have the edge programmer, oil return lines and a little more than stock fuel pressure. I hit 25 psi of boost, but an too scared of egt numbers to hit wot yet. If you buy more than 30, you better have some serious mods done.
Old 08-09-2013, 12:56 PM
I had a temporary boost guage installed for a week or so. I tapped into the Map sensor hose.
You need springs and push rods if you are hitting 30 psi boost.
Old 08-09-2013, 03:16 PM
richdawg's Avatar
This is a link to a thread I did a little over a year ago, maybe the gauge is faulty I'll have to check it out. I didn't bother getting a real boost gauge when I saw that I had that kind of boost pressure.
http://www.ford-trucks.com/forums/11...ost-video.html
Upgrades to Wastegated Banks Turbo? Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 10-15-2014 08:38 PM
boost red 1997 powerstroke 1994.5 - 1997 7.3L Power Stroke Diesel 12 07-12-2014 10:56 PM
Whats a Good Boost PSI?? Feonix1123 1999 - 2003 7.3L Power Stroke Diesel 68 09-18-2013 10:12 AM
Question for those with SCT canned tunes big inch 6.0L Power Stroke Diesel 13 07-06-2013 09:55 PM
Low Boost superdutymanfx4 6.0L Power Stroke Diesel 5 05-19-2013 10:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
