Speedometer/Odometer OOC
When I won't be driving my 95 F150 for an extended period of time, I sometimes pull fuse #8 to keep from draining the battery. Upon reinstalling the fuse last time, my odometer came on then went blank again and since then I have had no speedometer or odometer. I checked the other fuse that's associated with that circuit (#18 I think) and it was good. Does anyone have any idea what else to check? Thanks for any help.
Thanks for the reply Dixie460. I have never had the gauges out. Can you help me on where to check for power to the PSOM? Yes, I have a multi meter.
Check out the schematic below, courtesy of Steve83:
http://www.supermotors.net/getfile/9...om-fseries.jpg
You should have power (with reference to chassis ground) on circuit 54 (Light Green/Violet) and circuit 296 (White/Purple) with ignition switch ON.
This would be on the PSOM connector at the back of the gauge cluster. There's 3 electrical connectors, the PSOM is the small square one in the center.
baronvonblue
07-31-2018 09:24 PM
phoneman91
32
08-21-2013 08:37 AM
AK Outlaw
05-30-2011 08:10 AM
