2012 Ford Explorer Oil in coolant reservoir - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
Old 08-06-2013, 08:43 PM
Betali Betali is offline
Betali is starting off with a positive reputation.
Hey everyone,
We purchased a used 2012 Ford Explorer XLT back in April 2013 (19000 km). We brought it into the dealership last month for its check-up and the mechanic found oil in the coolant reservoir. After a few flushes and us returning with the same problem, they replaced the water pump and a few hoses and told us the problem was fixed. The memo says that after the job was done, they flushed the coolant again, took it for a test drive and there was no oil in the coolant. As a result, they told us the problem was fixed. The very next day I go get some groceries and check under the hood. Once again, oil in the coolant reservoir. It is not much...maybe a few millimeters but still obviously present. We took it back to the dealership and they are claiming that it is simply the remnants of oil from the leaking water pump and that it will never completely go away no matter how many times they flush the system. They are adamant that they have rectified the problem and that the remnants will do no harm to the future of the vehicle/engine performance. My question is whether this is true and we should accept that the 2 year old vehicle will always have oil in the coolant system until all the remnants burn off or whatnot or are they trying to not fix a bigger problem like the head gasket. I want to believe them but I find it difficult to believe that this will not affect the engine down the road. Any input would be great.
Betali
Old 08-06-2013, 11:48 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
".......never completely go away no matter how many times they flush the system......"
Now how can that be?
You need to find a dye for your oil, like this stuff:
Tracer Products Dye-LiteŽ TP3090-0601 - Gasoline Engine Oil Dye | O'Reilly Auto Parts
If that shop was worth a crap, they would have already done that and confirmed that the oil in the coolant is old or new.
I think you'll find the answer if you put the dye in.
Old 08-07-2013, 12:03 AM
Thanks for the info. Didn't even think of something like that. I shall ask them tomorrow how they plan to prove to me its old oil and not a leak they just haven't fixed and ask them about the dye.
2005 F150 Vibration Issue BrandonF15005 2004 - 2008 F150 2 11-20-2016 02:53 PM
Where else can coolant leak??? syjl 1994.5 - 1997 7.3L Power Stroke Diesel 17 12-14-2015 10:24 PM
oil in radiator, oil cooler? st8yd 1999 - 2003 7.3L Power Stroke Diesel 1 05-26-2015 06:09 PM
1997 F250 Heavy Duty CLEAN & WELL Maintained truck7575 Vehicles for Sale 1 04-09-2015 10:54 PM
2003 exploer leaking coolant from crankshaft stcspiderman Explorer, Sport Trac, Mountaineer & Aviator 4 01-21-2014 12:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
