What a day... my head's spinnin'!
Old 08-18-2013, 08:13 AM
wallster's Avatar
wallster
wallster is offline
Originally Posted by dmack91
So what engine/trans did you decide to go with?
A friend is selling me a chevy 350 from a 1990 former municipal truck. It only has 53K original miles and he's throwing in an aftermarket intake and carburetor. $500. but I have to pull it out at his shop. There's a manual transmission attached and since he's heavily in to local stock car racing I think we can find a cheap TH350 to use with it. I looked for a Ford 5.0 or an older 351 that was in decent condition but there wasn't much to choose from and the cost was at least double. I know most members hate these sbc motors in our old Ford trucks but I'm on a budget and since the price is affordable and with a rear sump oil pan (which will fit right into the truck with a mustang II IFS kit we're installing) I went with it. I wasn't even going to mention the engine but since the question was asked I thought I would spill the beans.
Wally
Old 08-18-2013, 09:22 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
So the question remains, ....why not keep the 390 and C6 you already owned?
Old 08-18-2013, 09:27 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
FE blocks look awesome in these trucks. They fill the engine compartment like a Boss 429 in a Mustang.
Old 08-18-2013, 09:53 PM
wallster's Avatar
wallster
wallster is offline
The 390 is a very wide motor. The stock battery holder didn't fit and the engine needed to come out just to remove the steering box. I believe it would have been a problem with the rack and pinion steering linkage and I would have had to change the oil pan pick up and the pan to a rear sump to fit with the new IFS cross member.
I was forced to sell my last '51 last winter to finish a garage/workshop and it really bummed me out. Once I was able to buy another old F1 I found this one and I want it to be similar but even better than the last one I had to sell. I liked the sbc in it because I could find parts everywhere and the motor ran well. I understand that people on FTE prefer the Ford engines in their trucks (it makes sense, after all, it's a Ford truck forum) but for my application I prefer the sbc motor. The 390 and C6 have a new home and the guy who bought it is putting it in a Mercedes SL believe it or not.
Thanks for asking the question.
Wally
Old 08-19-2013, 12:44 PM
old_dan's Avatar
old_dan
old_dan is offline
Subscribed....I want to see how your build goes. I like the clean slate.
You should try to find a stock crossmember....the structure helps to keep the frame from sagging outward where the body attaches at the front body mounts.
I'm not going to fault you for going with a sbc...as much as I like a sbf, I like seeing classic trucks on the road more. Once the hood is closed, nobody will know the difference.
Dan
Old 09-12-2013, 08:18 PM
wallster's Avatar
wallster
wallster is offline
It's been a while since I posted my progress but I've been pluggin' away on this project. I just finished the engine (see pics below, 1990 sbc with 53K miles) and the steering column is in place as well as the cross member. We should pick up some speed now. Next up is the fabrication of the motor mounts. All my parts are here so I'll update this thread as soon as I make more progress.
Wally
Old 09-12-2013, 08:41 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
That's looking good Wally.
Old 09-12-2013, 09:37 PM
AXracer's Avatar
AXracer
AXracer is offline
Nice! keep up the good work. Second time around goes smoother because you get the mistakes out of the way with the first one.
Old 09-12-2013, 09:46 PM
EffieTrucker
You put some serious elbow grease into that engine. It looks great.
Glad to know it's coming along nicely, and glad to see pics.
Old 09-13-2013, 08:14 AM
yamagrant's Avatar
yamagrant
yamagrant is offline
Wow! that engine looks great.
Old 09-13-2013, 11:06 AM
firstrider's Avatar
firstrider
firstrider is offline
[quote=EffieTrucker;13447084]FE blocks look awesome in these trucks. They fill the engine compartment like a Boss 429 in a Mustang.[/quot
Yes they do !!! I moved the steering box out 1" & down 2" to eliminate any clearance issues & so I could use the factory cast iron headers worth 35 more HP. . Just couldn't give that up !!
Old 09-14-2013, 07:41 AM
wallster's Avatar
wallster
wallster is offline
Wow! That's impressive, great job. (I know, I'm a d#ck for using a sbc)
Wally
  #28
Old 09-22-2013, 08:43 AM
wallster's Avatar
wallster
wallster is offline
Made a little more progress this week and I'm hoping to get the engine and transmission in place this week sometime. We finished making the engine mounts and once i receive a few needed parts for the front suspension we can get that buttoned up. Here's a few pics of the truck and the engine (with the transmission) that are ready to be transported to my buddy's shop. We're getting there slowly, but were getting there.
Wally
  #29
Old 09-22-2013, 09:50 AM
ohbrian's Avatar
ohbrian
ohbrian is offline
I feel your pain brother. I'm going through the same stuff right now on my 56. I can't blame you for going with an sbc motor, the price and availability of parts is exponentially better. Gonna tough it out with my 351 though until I blow it up.
  #30
Old 09-22-2013, 11:26 AM
AXracer's Avatar
AXracer
AXracer is offline
Why did you remove the R&P box mounts? I'm surprised to see you welded in the column floor cover plate before hooking up the steering. Personally I would not mount the bottom of the column to the frame. The cab is rubber mounted and moves around. typically the lower mount is attached to the floor so the column can move with the cab and it also isolates the steering wheel from road vibration.
Quick Reply: What a day... my head's spinnin'!
