460 cam shaft - Ford Truck Enthusiasts Forums
460 cam shaft
Old 08-06-2013, 12:02 PM
Chris Guthro's Avatar
Chris Guthro Chris Guthro is offline
Chris Guthro is starting off with a positive reputation.
460 cam shaft
I need to know if this camshaft is way to radical for my engine. First off its a 1978 Lincoln 460. Its stock so far other than the 1970 straight up timing chain ive bought to put in it so far. Ill be adding long tube headers and hopefully a weiand stealth intake and maybe a bigger carb. the guy has it brand new in the box and will sell it for 100 bucks as its to small for his 800 horse 545. he said the card has 595 deg intake and 621 exhaust. With those future mods is this cam to big without doing anything to the heads? its going in a 84 f150 2wd with c6 and 9 inch limited slip.
BIG BLOCK V-8 CAMSHAFT 385 SERIES (429/460) | Part Details for M-6250-C460* | Ford Racing Performance Parts
Old 08-06-2013, 12:09 PM
what would be a good one?
Old 08-06-2013, 03:28 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
That cam going to work with the low compression in your stock '78?
I can't find Ford Racing 460 crate engines anymore. They say they use that cam in M-6007-C460, but I can't find that engine on their site.
I did find this, check post 3:
What does these # tell me M-6007-C460 - 460 Ford Forum
If that cam was used by Ford in an 11:1 crate motor, I would guess it will be a complete pooch in an 8:1 motor.
You would probably have to swap springs and possibly other work as well, as the stock '78 springs would probably coil bind with the extra lift.
Best do your rebuild all at once. A part here, a part there and you'll go broke buying gaskets along with not getting much for your efforts.
Old 08-09-2013, 09:36 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
It is WAY too big.
Edekbrock 1411 Throttle Linkage Problem FrankGRUN Fuel Injection, Carburetion & Fuel System 4 07-10-2016 03:25 AM
460 Throttle Linkage Problem FrankGRUN Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 04-10-2016 03:27 PM
another 460 swap redneck_davis 1973 - 1979 F-100 & Larger F-Series Trucks 76 12-16-2015 08:21 AM
Trying to get 400hp from a 390? tartar_sammich FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 02-13-2015 04:41 PM
Convince me - 429/460 vs. 351/400 bbtkd Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 06-08-2002 05:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
