4 barrel intake on 360/390? - Ford Truck Enthusiasts Forums
Old 06-13-2003, 06:30 PM
Damon Dimick Damon Dimick is offline
Damon Dimick is starting off with a positive reputation.
Hey all, new to the board. I have a 76 F250 hi-boy, which is pieced together to say the least. Not sure if I have the 360 or 390 mill. The guy I bought it from said it was the 390. The carb spacer on the intake is for a 4-barrel, with an aftermarket carb. I heard that only some of the 390's came with the 4 barrel. The question is what is the intake on this motor? Is the intake the same for the 360 and 390? Is it the same for a 2 or 4 barrel? Is it possible that the intake is for a 2 barrel 360, with a 4 barrel carb spacer? Also, what's the best way to find out if it's the 360 or 390? Any and all help would be appreciated, as I'm a newbie to these Fords. Thanks.
Old 06-13-2003, 06:37 PM
gtex's Avatar
gtex gtex is offline
gtex is gaining momentum as a positive member of FTE.
You'll need to describe the intake more, find casting numbers if possible.
I'm not sure they ever put 4V setups on 360s, but I also beliveve that there are few if any factory 4x4 390 setups.
The bets way to determine if you have a 390 is to measure the stroke or ID the crank. Do a search in this FE forum to find several methods of measureing the stroke.
Now , with the age of these trucks there is often no telling what somebody else has put in the truck.
I think the 2V intakes have a smaller intake opening, so it would require an adapter for a 4V carb on a 2V intake.
Old 06-13-2003, 07:05 PM
chissler chissler is offline
chissler is starting off with a positive reputation.
No 4-barrel 360's
No 4x4 390's
You can use an adapter to put a 4barrel on a two barrel intake, but it doesnt work very well.
Intakes interchange.
Gtex is right, these old trucks can and more often than not do have anything.
390 and 360 Shawnboylk 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-25-2016 07:20 PM
Its not a 360! Duckmang 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-04-2013 02:45 PM
390 stock 2 barrel or 4 barrel luv2ski 1967 - 1972 F-100 & Larger F-Series Trucks 5 07-28-2012 02:49 PM
Cast Iron Intake 4 barrels for 360/390 Kalve FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 10-11-2010 09:52 AM
performance engine build questions 1975 f150 360 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 10-17-2003 12:35 PM
Tags
1969, 332, 360, 390, 4barrel, adapter, barrel, barrell, carb, ci, engine, factory, fe, ford, hd, intake, spacer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
