Battery not receiving a charge - Ford Truck Enthusiasts Forums
Old 08-06-2013, 12:23 AM
OKC54f100 OKC54f100 is offline
OKC54f100 is starting off with a positive reputation.
So let me say this first. I am not a mechanic or anything close to it. I do however take pride in trying to do things myself. So my problem is this. I have a 1954 Ford f100 that has a 292 Y Block in it freshly rebuilt. I put in a new voltage regulator (12v) and a new Battery. I have also hooked up 2 different Generators and I am getting the same thing which is my battery going dead after several starts. Once again I am not a mechanic so I would like to know of maybe something I could do or have done to find out what is causing this. I have also read several other threads about this subject or similar to it and it is way over my head. I need extremely simple.
any info will help thanks.
Old 08-06-2013, 11:25 AM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
OKC
Is the starting draining the battery or the time between? Will the battery start the truck after it is connected but not used for a few days?
DW
Old 08-06-2013, 11:55 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
OKC,
When you install a generator, usually you have to flash the field to get the generator to generate for the first time that you use it.
I don't have a manual for a 54, but there are two common ways to do this. One, with the engine running, you provide power to the field lead for a couple of seconds...by jumpering a wire directly from the battery to the field lead. If your 54 is 12v negative ground, you would jump from the battery positive to the "F" connection on the generator.
You do this because when generators are unhooked and stored, the iron magnets lose their magnetism. Those magnets are augmented by wire windings around them (an electro-magnet) which strengthen the magnetic field inside the generator. In everyday use, the windings create enough magnetism around the iron cores to leave them magnetized...weakly, but enough residual magnetism will be there to energize the generator when you start turning it (i.e. running the engine).
The other method is to motorize the generator by removing the belt and, depending on what schematic your shop manual provides, you usually power the "BAT" terminal and ground the "F" terminal on the generator. It should turn like a motor. The same thing happens to the iron cores...they become magnetized.
I prefer the flashing the field approach because you can hook a multi-meter to the battery and watch the battery voltage when the generator starts generating.
If you do the running engine flash-the-field approach, you should have the engine running at a high idle...enough for the generator to be charging. Generators don't work very well at low RPM settings. If it works, you should see static battery voltage at the battery (something like 12 to 13 volts). When the generator comes on line the voltage will go higher. After you detach your jumper lead (since you only held it there for a few seconds), the battery should slowly climb to regulated voltage (should be around 13.5 volts).
Dan
Old 08-06-2013, 12:32 PM
Quote:
Originally Posted by old_dan View Post
OKC,
Dan
Thanks for taking the time to write that out. I will give this a try and let you know the results.
Old 08-06-2013, 12:33 PM
Quote:
Originally Posted by FortyNiner View Post
OKC
DW
Starting the truck is what is draining the battery.
Alternator Problems. Help. Shutech 1999 to 2016 Super Duty 1 04-21-2015 10:31 PM
Hard Starting problem I8AHEMI 1999 - 2003 7.3L Power Stroke Diesel 18 03-16-2015 04:03 PM
Alternator Problems. Help. Shutech 1999 to 2016 Super Duty 0 07-18-2014 04:32 PM
68 shortbed 460 hard starting carb backfire corytcline 1967 - 1972 F-100 & Larger F-Series Trucks 25 09-10-2012 10:35 PM
2001 4.6 Misfiring (A Sad Tale) tdchandler 1997 - 2003 F150 0 05-08-2006 07:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
