Low compression after cam swap? - Ford Truck Enthusiasts Forums
Old 08-05-2013, 10:24 PM
bassdude bassdude is offline
bassdude is starting off with a positive reputation.
Took the old 460 out of my Scout rock crawler to freshen it up before installing it in my 77 Scab. Replaced the crank and bearings, put in a Lunati Voodoo cam at the same time.
Decided to check compression by hand with a ratchet on the crank. Only getting 30# on all cylinders. I've got a Cloyes roller chain in the straight up position.
Should I get it to where I can crank it with the starter before worrying about it? Try the Timing chain on the advanced mark?
Old 08-06-2013, 02:52 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
New cam, what about:
--lifters
--pushrods
--rockers
--springs
If something is not compatible with the increased lift of the cam, or if the base circle of the cam is different, low cylinder pressure might result.
Cam timing would also be a suspect, but seems unlikely.
You are not exactly "spinning" the motor with that ratchet, so a lot of pressure will bleed off before you hit TDC, more so with a longer duration cam.
If you don't see anything "funny" with the rest of the valve train, try it with the starter before you make a final decision.
Old 08-06-2013, 05:35 PM
yeah, everythings new. I think I will get it sitting in the truck then try it with the starter.
2008 5.4 timing sosotwo 2004 - 2008 F150 9 08-04-2014 12:49 PM
86 5.0 EFI Valve to Piston clearance BigDoug 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 07-16-2014 11:35 PM
02 explorer 4.0 timing copyman Explorer, Sport Trac, Mountaineer & Aviator 0 06-20-2014 06:32 PM
timing chain set 65 352 jpmillbauer 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-16-2014 08:35 AM
Replaced timing gear and chain Nevada Dan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 07-31-2011 10:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
