A few Ford F250/F-350 parts - Ford Truck Enthusiasts Forums
Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Old 08-05-2013, 08:46 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
Category: Interior
Price: $0
Private or Vendor Listing: Private Listing
Item Condition: Used
I've got a few parts sitting around that I don't have a need for.
Most of them were taken from a 96 F350 that was wrecked and the outside was damaged.
I've got a complete passenger door, glass linkages, etc. It is parts only since it was one of the damage areas on the outside. Make offers if you need anything from it.
I've got a hydroboost MC from a 97 F450. No cruise provision. Probably have a couple hydroboost lines I didn't use so I will ship those with it.
Working brake master and booster from a 96 f350.
I've got 3 serp belts from a 97 f350, 8 rib pully. I don't think they were ever used, but they don't have any packaging.
Various tan trim interior pieces from a 96 f350 crew. I've got the windshield trim.
Lower dash panel/by steering column.
Windshield to headliner trim.
Both b pillars with belts.
2 mint tan sunvisors.
I've got an ac compressor from this same truck. Unsure on condition.
I also have the factory underhood harness from this truck, e4od truck. It was cut by the PO when he was removing the engine. It will need to be soldered back together.
Factory spyder from the 96 f350.
Underhood insulation for a 7.3 diesel. This one will be expensive to ship so I may have to fold it in half to get a decent shipping rate.
I've got a 2012 f550 rear seat. It is a vinyl bench. It was pulled from a truck with 30 miles on the odometer in favor of black leather. It will need to have dust cleaned off it. But otherwise has never been sat in.
Not really sure what things are worth price wise so I will take offers on it. I mostly just need this stuff gone for the space.
Old 08-07-2013, 05:03 PM
Any interest?
Old 08-08-2013, 10:50 AM
Mr.travo Mr.travo is offline
Mr.travo is starting off with a positive reputation.
The lower dash piece- Are you talking about the black trim piece that goes around the gauge cluster and steering column?
Thanks!
Old 08-08-2013, 05:28 PM
Quote:
Thanks!
The one where the fuse panel is and the little cubby on the right side of the steering wheel. Don't have the instrument cluster bezel unfortunately.
Old 08-08-2013, 08:04 PM
Ahhhh, ok Glove. Ya, the black bezel is what I was looking for. I appreciate your help!
Old 08-08-2013, 11:03 PM
scott79's Avatar
scott79 scott79 is offline
scott79 has a good reputation on FTE.scott79 has a good reputation on FTE.scott79 has a good reputation on FTE.
PM sent...
Old 11-23-2013, 07:17 AM
bondob bondob is offline
bondob is starting off with a positive reputation.
is the 96 f350 4x4 auto drw w/od ?
do you have the linkage rod for the transfer case ?
you can reach at brianbondo@yahoo.com or call 6172795737
thanks
brian
Old 02-04-2014, 09:13 PM
mike55333 mike55333 is offline
mike55333 is starting off with a positive reputation.
Would you possibly have the drivers side door panel courtesy light unit or red and white plastic lenses? I have a '97 crew cab but the courtesy light units should be the same.
Old 05-04-2014, 10:20 PM
reamer's Avatar
reamer reamer is offline
reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.
Tan seat belts still available?
Old 05-09-2014, 06:52 AM
tonyj54 tonyj54 is offline
tonyj54 is starting off with a positive reputation.
Do you still have the a/c compressor?
Old 05-14-2014, 04:59 PM
lisagoud lisagoud is offline
lisagoud is starting off with a positive reputation.
and the hydroboost setup?
Old 05-15-2014, 12:48 PM
Green Griffin 420's Avatar
Green Griffin 420 Green Griffin 420 is offline
Green Griffin 420 is starting off with a positive reputation.
I'm looking for a lower air box snorkel from a f250 with a 7.5/460. Would you have one of those?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
96-97 7.3 F350 Parts glovemeister Ford Truck Parts for Sale 12 05-18-2015 01:08 PM
OBS Parts glovemeister Ford Truck Parts for Sale 11 09-02-2014 04:10 AM
HYDROBOOST Jmudweiser Ford Truck Parts for Sale 0 06-01-2014 07:17 PM
HEADLINER luvmy150s 1987 - 1996 F150 & Larger F-Series Trucks 1 10-30-2013 06:22 PM
1996 F350 part out glovemeister Ford Truck Parts for Sale 5 08-18-2012 07:48 PM
