how much horsepower does my 390 make? - Ford Truck Enthusiasts Forums
Old 08-05-2013, 05:28 PM
riverguideguy riverguideguy is offline
riverguideguy is starting off with a positive reputation.
my guess is somewhere between 300-400 but does anyone have a better guess? its a car 390 from a 63 thunderbird with 9.5 to 1 cr. performer rpm intake. edelbrock 600 carb. k&n air filter. cloyes strait up timing gear set. comp cams 268h camshaft. hedman headers with 2.5 inch exhaust and glasspacks and msd ignition system. anyone with a similar engine build know there hp? its got plenty of power but i was just curious if someone had an actual hp number. i hate when people ask me about the hp and all i can say is i dunno
Old 08-05-2013, 05:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Old 08-06-2013, 11:52 AM
i don't have 1/4 mile times to use that calculator i was hoping maybe someone had the factory horsepower numbers. i figure if i added about 60-70 to that number id have a pretty good estimate of my horsepower.
Old 08-06-2013, 12:48 PM
mikeo0o0o0's Avatar
In '63 the T-Bird 390 4bbl was 300 HP, the 390 with tri-power was 340 HP. There was also a low compression export only model rated at 275 hp.
Old 08-06-2013, 03:11 PM
thanx! so next time anyone asks me i think its safe to tell em around 350-375 horsepower without being to far off the closest dyno to me is 2 hours away and they want $120 for 3 pulls on the dyno
Old 08-06-2013, 11:11 PM
pat67shorty's Avatar
pat67shorty pat67shorty is offline
pat67shorty is gaining momentum as a positive member of FTE.pat67shorty is gaining momentum as a positive member of FTE.
1970 car 390, 9.5:1, Streetmaster intake, 780 holley, MSD, Headmans, 2.5" duals with delta 40's, stock 2V cam. 226/306 at the wheels. Figure about 60 HP lost between the C6 and drivetrain.
400HP out of a 360??? steve33444 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 102 09-17-2015 11:58 AM
390/360 carb 110 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 11-01-2013 09:06 AM
1969 f250 highboy? jamesh23 1967 - 1972 F-100 & Larger F-Series Trucks 29 08-07-2013 07:39 PM
What to do with 390? SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-28-2013 01:39 AM
4.6 V8 power output Busguy71 Modular V8 (4.6L, 5.4L) 15 01-24-2013 03:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
